Suspension H&R 19mm Sway Bar question
Old Nov 9, 2007 | 07:19 PM
byhsu's Avatar
byhsu
Does the bar come with two position for the bolts? And if it does, which one do you use? The outer one or the inner one? I mainly will use the car for street, don't think I will track it or go autoX.
Anybody have a picture of the sway bar?
Old Nov 9, 2007 | 10:50 PM
nypepper's Avatar
nypepper
the h&r has two adjustment holes the inner is soft the outer is stiff
mine is set to stiff and is just right for my driving style
you should try both and see
Old Nov 10, 2007 | 07:14 PM
byhsu's Avatar
byhsu
I will not track my car so which setting should suit me? the inner one (softer)
Old Nov 10, 2007 | 10:03 PM
oldopelguy's Avatar
oldopelguy
physics
The one out closest to the end of the bar is the softest setting, as it's lever arm is the longest, start there on a street car.
Old Nov 11, 2007 | 10:51 AM
byhsu's Avatar
byhsu
Oh, so the one that is furthest from the sway bar, at the end of the bar is the softest. Thanks for letting me know, i was getting that confused.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
Mini7
Feb 2, 2016 07:52 PM
minimofo
Sep 9, 2015 10:29 AM
nomar116
Aug 10, 2015 11:24 PM
