Suspension M7 Strut Plates
Old Aug 25, 2007 | 05:37 PM
  #26
JIMINNI's Avatar
JIMINNI
Originally Posted by RIPPER
I have the m7 srp and think they are great but in hind sight I should have paid a little extra an gotten strut tower brace. that is only 199.00 and does the same thing the srp's do and also helps keep the front end from flexing. Maybe I can sell the srp's for 90.00 shipped and put that money towards the stb.
Yea kinda goofy that they sell them separately .
Old Aug 25, 2007 | 05:43 PM
  #27
Rally@StanceDesign's Avatar
Rally@StanceDesign
Cooper owners need protection too......
  #28
mozzarella's Avatar
mozzarella
Originally Posted by Deviant
Look at it like this, when the struts mushroom, studs do not just move vertically, they tend to fan outward as well. By having a thick piece of metal bolted to the top you not only prevent the upward motion of mushrooming but also the deformation of how the studs sit in the strut tower.
Standard strut ||
Mushroomed strut \ /
If this is the case, would you get the same protection by just reinforcing the bolt holes?
Old Aug 25, 2007 | 08:24 PM
  #29
JustJAY's Avatar
JustJAY
There was a thread somewhere, cant find it now, but the guy wetted his liner but also used hairspray, he said it kept the liner in a perfect molded shape. I'll get around to trying this one day for my car . Just some info to share .
Or you could remove the bonnet liner like I did.
Old Aug 25, 2007 | 08:58 PM
  #30
DPCooperS's Avatar
DPCooperS
Has anyone thought of making the strut tower plates out of carbon fiber??
Dave
Old Aug 25, 2007 | 09:08 PM
  #31
maxmini's Avatar
maxmini
Some people do not want to go for the full strut tower brace for a variety of reasons but still would like some protection against the dredded mushroom. For those people we offer just the SRP's by themselves. We thought it was a good idea .
Randy
M7 Tuning
Old Aug 26, 2007 | 01:21 PM
  #32
JIMINNI's Avatar
JIMINNI
Randy
M7 Tuning
Yea I guess your right, they do save $70. .
Old Aug 26, 2007 | 02:57 PM
  #33
Rally@StanceDesign
Dave
Solid carbon fiber? Hollow certainly wouldn't add any strength.
Old Aug 26, 2007 | 03:24 PM
  #34
minjae's Avatar
minjae
i pretty much saved $100.
got my srp's for about $100 shipped.
one thing i noticed about them was that they ride a tiny bit different when going over bumps. some bumps feel not as 'rough' feeling while other bumps are a little more 'rough'. hard to explain. but i go over bumps without worries.
Old Aug 26, 2007 | 04:04 PM
  #35
Gil-galad's Avatar
Gil-galad
For the type of motoring I do (normal driving; spirited twisties on occasion but no rallys or track) the SRPs were exactly what I was looking for. I never push the car to the point that I need to worry about front end flex, so the brace would have just been extra $$ on bling under the bonnet--not needed or wanted.
I love my m7 SRPs and now drive with a lot more confidence (worries are limited to the motor mounts )
Old Aug 26, 2007 | 06:04 PM
  #36
jefeant's Avatar
jefeant
That's what I did = wetted the hood liner. It worked great, the perfect contour.
Old Aug 27, 2007 | 02:45 PM
  #37
DPCooperS's Avatar
DPCooperS
[RallyMINI,
Solid carbon fiber? Hollow certainly wouldn't add any strength.]
I work in the aviation field, we have a shop that can build up layers of carbon fiber, I was thinking for the plate to be about 3/4 inch thick>
Dave
Old Aug 27, 2007 | 03:05 PM
  #38
SayGoodbye's Avatar
SayGoodbye
Old Aug 27, 2007 | 03:18 PM
  #39
Rally@StanceDesign
would 3/4 inch of CF be structurally comparable to the current SRP's? Just curious
Old Aug 29, 2007 | 06:03 AM
  #40
DPCooperS's Avatar
DPCooperS
That is my question, what would the ratio of CF be to Alum. for the area of the strut tower.
Dave
Old Sep 1, 2007 | 10:24 PM
  #41
maxmini's Avatar
maxmini
Originally Posted by terryg
Put a piece of paper on top of a mattress and punch it. Notice how the paper deforms?
Now try the same thing with the paper on a concrete floor
The goal isn't to prevent the force from acting on the top of the strut tower, it's just to make the force required to deform the metal higher than any force normally experienced in that area. A hard enough slam will still rip the sheet metal (with plate attached) right off the car. It'll just come off flatter than without the reinforcement plates
This is very well said and I may have to use this discription in the future. The dry wall explanation by Myzamboni was a good one as well. Thanks to both you guys.
Randy
M7 Tuning
Old Aug 20, 2008 | 03:57 PM
  #42
OldRick's Avatar
OldRick
Well, the question is moot, because Mini-Madness has announced strut-top reinforcemnent plates that should actually work, as they fit between the strut and the tower, instead of on the wrong side, on top of the tower.
Check them out at http://www.mini-madness.com/index.as...ROD&ProdID=334
Old Aug 20, 2008 | 04:03 PM
  #43
AutoXCooper.com's Avatar
AutoXCooper.com
camber plates also work very well and add camber adjustment to the front too.
Old Aug 20, 2008 | 04:08 PM
  #44
Rally@StanceDesign
And they wouldn't raise the car 4mm's
The madness plates don't seem to be much more surface area than the OEM top strut mounts. Is the idea that they will spread the force evenly across the weak strut tower
Old Aug 20, 2008 | 04:13 PM
  #45
AutoXCooper.com
not MORE wheel gap
Old Aug 20, 2008 | 05:21 PM
  #46
Longboard110's Avatar
Longboard110
What Im seeing is that it is thickening the top of the tower, thus making it stronger with less chance of pushing up. Sounds like a decent option for those who do not want camber plates, of course depending upon the thickness and type of material they used. The old style M7 and others are junk when they are not used with something like camber plates of hopefully these.
Old Aug 20, 2008 | 05:44 PM
  #47
AutoXCooper.com
"junk" I don't think that's really the word to use with products that have years and countless miles of use with more happy customers then unhappy.
I'm happy to see another product to address the issue and look forward to seeing it installed and the reports.
ej
Nov 17, 2015 09:21 PM
vargasgal
Sep 17, 2015 10:02 AM
Sep 11, 2015 01:15 PM
USA-RET
Sep 8, 2015 01:50 PM
Suspension Products
Sep 3, 2015 09:41 AM
