Mini Cooper Suspension Upgrade Stage 3 Kit W/ Dynamic Damper F56
Part No: G3NMK4021
SALE Price $2355.00
Was: $2,359.85
You save: $4.85
This is Special Order Only Item
Stage 3 Suspension Upgrade Kit for MINIs WITH the Dynamic Damper Control blends the racing performance experience of Mini Mania with the demands of the enthusiastic MINI street and track driver. Based on the KW Coilovers, these kits are intended for the more 'serious' street / track drivers.
Fits the following models with the optional Dynamic Damper Control:
2014+ F56 MINI Cooper and Cooper S Hardtop
THE STAGE KITS
This Kit includes:
- KW Coilover Variant 1 Suspension Kit
- NM Engineering 25mm Rear Anti-Sway Bar
- NM Engineering Adjustable Rear Sway Bar Drop Links
- NM Engineering Adjustable Rear Control Arms - 1 pair
- Under Chassis Brace system
When we talk about 'improving' the suspension, we always begin with a larger rear sway bar. This upgrade reduces the inherent 'understeer' built into the car for safety and provides a more 'balance' car. This allows you to carry more speed into and out of the corner while keeping the car 'flatter' in the corners. The Adjustable Drop Links replaces the factory 'plastic' units for reliability and adjustability.
The KW Coilovers lower the center of gravity and keeps the tires planted on the road. They are height adjustable with some versions offering variable damper settings.
Anytime the MINI is lowered, the rear negative camber is greatly increased and needs to be corrected. This is the reason for the Adjustable Rear Control Arms included in this kit. This kit includes a pair of the adjustable arms which will allow you to optimize the rear alignment.
PelicanParts.com
Suspension Products
05-17-2016 08:42 AM
PelicanParts.com
Suspension Products
05-17-2016 08:42 AM
Suspension Products
10-29-2015 10:23 AM
Tires, Wheels & Brakes
10-28-2015 10:49 AM
