Mini Cooper Suspension Upgrade Stage 4 Kit W/o Dynamic Damper F56
Old 10-29-2015, 10:23 AM
Mini Mania's Avatar
Mini Mania is offline
Part No: G3NMK4022
SALE Price $3295.00
Was: $3,349.75
You save: $54.75
This is Special Order Only Item
Fits the following models without the optional Dynamic Damper Control:
2014+ F56 MINI Cooper and Cooper S Hardtop
Stage 4 Suspension Upgrade Kit for MINIs without the Dynamic Damper Control blends the racing performance experience of Mini Mania with the demands of the enthusiastic MINI street and track driver. Based on the KW Coilovers, these kits are intended for the more 'serious' street / track drivers.
MINI did a wonderful job with the handling on the new 3rd generation F-series MINI, but their design is on the conservative side to appeal to the widest segment of the market. This leaves room for improvement for the 'enthusiast' type driver.
When we talk about 'improving' the suspension, we always begin with a larger rear sway bar. This upgrade reduces the inherent 'understeer' built into the car for safety and provides a more 'balance' car. This allows you to carry more speed into and out of the corner while keeping the car 'flatter' in the corners. The Adjustable Drop Links replaces the factory 'plastic' units for reliability and adjustability.
The KW Coilovers lower the center of gravity and keeps the tires planted on the road. They are height adjustable with some versions offering variable damper settings.
Anytime the MINI is lowered, the rear negative camber is greatly increased and needs to be corrected. This is the reason for the Adjustable Rear Control Arms included in this kit. This kit includes two pairs of the adjustable arms which will allow you to independently optimize the rear camber and Toe alignment.
Suspension Products
10-01-2015 11:53 AM
Suspension Products
10-01-2015 11:14 AM
Tires, Wheels & Brakes
10-01-2015 08:55 AM
09-29-2015 12:17 PM
09-29-2015 12:16 PM
Quick Reply: Mini Cooper Suspension Upgrade Stage 4 Kit W/o Dynamic Damper F56
