Megan Racing Coilover Feedback
Old Oct 27, 2017 | 11:23 AM
  #26
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Originally Posted by Minibeagle
Any idea what the spring rates are for these coilovers, front and rear?
The Euro 2 with the front camber and rear pillow ball mounts are supposed to be 6kg front and rear.
The less expensive Euro coil with non-adjustable front and that use OEM rear mount are supposed to be 6kg front, 5kg rear.
http://www.meganracing.com/product_d...d=81&catid=105
http://www.meganracing.com/product_d...=1486&catid=29
Old Nov 16, 2017 | 11:28 AM
  #27
Subw00er's Avatar
Subw00er
Can anyone tell me if they are able to keep the same ride height as stock with the Megan Euro coilovers? I just talked to a vendor and was about to purchase, but he said it will drop it at least .5-1"?!?! I'm holding off for now because I want to keep the same ride height as stock (r52 JCW).
The only confirmation I've found is at WMW's website: https://www.waymotorworks.com/megan-...coilovers.html - but I dont trust it really since its the only place listing this and it appears that all coilovers do at least a .75" drop!?
"You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance"
On a side note, how low can we functionally go before rubbing ensues?!
Old Nov 16, 2017 | 01:49 PM
  #28
UW Mitch's Avatar
UW Mitch
Coilovers are typically adjustable - that's the whole benefit. If you look at your mini right now, it's got a "coil over" in that the spring goes around the shock, it's just many aren't adjustable. So you should be able to maintain stock ride height.
In terms of how low you can go before rubbing is a function of tire size. My car is about 1" low and with my 215/45R17 tires no issues, but my 225/50ZR16 track wheels, tons of rubbing (taller, wider tire).
~Mitch
Old Nov 16, 2017 | 08:41 PM
  #29
Subw00er's Avatar
Subw00er
Just a follow up.. megan says there is a .6” drop minimum.
Old Jan 5, 2018 | 08:43 AM
  #30
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Can anyone confirm or deny that you need spacers in the front with the Megan coilovers and OEM 17" wheels?
Old May 30, 2018 | 05:03 PM
  #31
mistro's Avatar
mistro
Bump for someone to answer this question and a JCW BBK too. I would not think you need spacers but I'm considering making the move to these. Thanks.
Old May 30, 2018 | 07:14 PM
  #32
Subw00er's Avatar
Subw00er
I had the megan EU's (newest version) and the advanti dst storm 17x7 - there was ample room - 2-3 fingers if memory serves. You can do some homework and look up the advanti dst storm offsets compared to stock. I think they are pretty close.
Old May 30, 2018 | 07:45 PM
  #33
mistro's Avatar
mistro
Old Jun 1, 2018 | 02:49 AM
  #34
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The 17x7 Storm wheels come in a +40 or +35 offset, stock is +44. The Storms would be the equivalent of running an 8mm or 13mm spacer on the stock wheel.
Old Jun 1, 2018 | 06:49 AM
  #35
Bnourai's Avatar
Bnourai
I am on euro 2's and 16's no rubbing and the car is as lower than just about the end.
Like the ride it is a little stiff but serves me well, no spacers and I have a 35et wheels.
Old Jun 1, 2018 | 07:33 PM
  #36
Subw00er's Avatar
Subw00er
Mine are the 35mm offset with 205/45R17
Old Jun 4, 2018 | 03:37 AM
  #37
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I think you guys are missing the point of the original question... Do you need spacers with OEM wheels? Claiming “No spacers are needed!”, then following with your ‘aftermarket’ wheels specs doesn’t answer the original question.
Old Jun 4, 2018 | 03:54 PM
  #38
Subw00er's Avatar
Subw00er
Well, then do you own research and call megan if you dont like the answers. we're just trying to help. We dont work for you.
Old Jun 5, 2018 | 05:01 AM
  #39
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Old Nov 22, 2019 | 02:01 AM
  #40
oldr_4_me's Avatar
oldr_4_me
I just installed the Euro II's on my MCS vert 07 and have the stock 17" and did not need any spacer front or back. Also, had no issues with my Wilwood BBK. The only glitch is that now I have to severely raise the height all around. Went to get an alignment and the shop informed me that the car was too low for the system even with special ramps for lowered cars. Yet I am not bottoming out ... Yet.
Old Jan 10, 2020 | 07:09 AM
  #41
R53Madness's Avatar
R53Madness
What are you guys running for end links? I plan on lowering my R53 about 2 inches and heard of people running into issues with stock end links hitting the LCAs.
Old Jan 15, 2020 | 06:30 PM
  #42
fullmoonguru's Avatar
fullmoonguru
I found that the instructions for setting spring sag were misleading and led to riding on the bump stops with a very harsh ride. I found instructions in this forum somewhere that led me to tune them with more preload which cause them to ride higher in teh stroke with a better ride. Still though, I wish they had more travel. It's not slammed, I think my drop is about 1.25", maybe 1.5". If I adjust the dampers down in the middle setting the smaller bumps feel fairly good but it's very bumpy over larger bumps and slams pretty hard on nasty ones. This is even after installing micro-cell bump stops. Setting the dampers almost to full stiff, especially in front, results in a ride that's stiffer over the small stuff but much less bouncy over big bumps because it's keeping me off of the bump stops.
In the end, I'm not real happy with them. I thought the benefit of coil overs would be to have it somewhat lower and still have reasonable travel because of being able to lower the ride height and adjust the springs separately. Instead I think they feel more like struts with short springs.
Old Jan 16, 2020 | 07:33 AM
  #43
GotGrit's Avatar
GotGrit
Coming in a bit late to the game - I purchased a set of these back in April 2017. I've put about 15,000 miles on them without issue. I've also run them on the track (Laguna Seca and Thunder Hill) without any trouble, the car handles fantastically! I run them at the 13th tooth on the damper setting and 1/4" spring preload. They are stiff. I only lowered it about 1.5 inches so I can continue to go over speedbumps without issues. Due to the short throw - my rear passenger tire does come off the ground occasionally when entering some of the dips into shopping center parking lots LOL.
https://www.amazon.com/gp/product/B01BUEBTNQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01BUEBTNQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
BushOner
Mar 12, 2022 08:51 PM
Vaderm34
Sep 27, 2015 09:25 PM
Ryan Caballo
Sep 4, 2015 12:20 PM
