Oil in coolant problem
Old Mar 9, 2007 | 11:13 AM
vano's Avatar
vano
I dropped of my 04 MC at Helix this morning for some basic maintenance stuff. I also asked him to take the car for a spin and tell me what he thinks about the engine sounding more rough than normal. In the last 2 or 3 months I had been noticing more vibration/feedback once i got past 3.5K rpm. The powder delivery had also gotten even more erratic with torque slumping every 500rpm.
Eric called me back a couple of hours ago and told me that he saw a lot of oil in my coolant. He is thinking that either the head gasket has blown or something worse is going on inside the block. The situation is sketcy enough that he doesn't recommend even running the car, so the mini will stay there until he can get the minimum amount of parts he needs to get the gasket change started. He was planning on draining the oil from the oil pan to see if there is any cooland in there. I really hope that is not the case.
Has anyone else seen or had this kind of problem on a MINI? Just wondering if this is a semi-known problem or if I am one of the blessed few to have a major engine problem. The car has 54K miles on it. I generally drive it very easy on the road, shifting at 3k, but I do autocross it pretty regularly in the summer. No track days, drag launches or heavy abuse at all.
Old Mar 9, 2007 | 02:16 PM
herbie hind's Avatar
herbie hind
the heat exchanger has been known to fail causing this . hopefully you got it in time . as long as no coolant has hit the bearings . good luck .
Old Mar 9, 2007 | 02:26 PM
Dr Obnxs's Avatar
Dr Obnxs
A leak down test will tell you if the cylinders are good.
I blew a head gasket, but only after an overheat. I didn't see oil in the coolant though..... When mine went it wasn't drivable.
Matt
Old Mar 9, 2007 | 03:33 PM
sdv515's Avatar
sdv515
i am leaking greenish oil from someplace in the engine bay as we speak. i think i may have a blown head gasket too. i noticed the problem a little while ago when i was meeting a friend somewhere, i looked down and my temp gauge was all the way up. i checked the antifreeze resevior and it was bone dry. got it home and looked under it and there is a lot of liquid dripping down the bottom of the block.
the few days before all this happened i noticed my temp gauge was above normal but only slightly.
Old Mar 9, 2007 | 05:11 PM
herbie hind
well that sucks ; pull the dip stick and look for the bad news . plugs too . that's a serious bummer . you'll hope your bearings are good . if so it's not too bad . do get it checked for warpage though . any competant machine shop can do this . hell ; you can too with a good straight edge . if it's straight you're cool . just put another gasket on her .
Old Mar 9, 2007 | 07:15 PM
sdv515's Avatar
sdv515
your telling me to check the edge of the cylinder head? what am i checking the plugs for? sorry for the questions
Old Mar 9, 2007 | 07:20 PM
caminifan's Avatar
caminifan
Whether it is a head gasket, failed heat exchanger, cracked block, or whatever, the repair should be covered under warranty. Just make sure that the bearings are checked if the engine is not replaced. Personally, if my car had oil in the coolant, and the engine wasn't replaced, I would ask how they were going to prove that the bearings were not damaged. The issue is not limited to the crank bearings; there are all manner of bearings that could be damaged from coolant in the oil.
Edit: Unless the car is out of warranty, which it appears it is (54,000 miles). Sorry for the bad news. Hope it is just a blown head gasket. But be prepared for something worse.
Old Mar 9, 2007 | 07:23 PM
caminifan's Avatar
caminifan
The flatness of the cylinder head needs to be checked to confirm that the cylinder head is uniformly flat across its entire length. The plugs can tell you where the cylinder head gasket is failing (if the cylinder head gasket is indeed the source of the problem). But this is something that the dealer should be doing (unless you are out of warranty).
Edit: Which indeed the car is (out of warranty).
Sorry for the confusion.
Old Mar 9, 2007 | 07:32 PM
ricky's Avatar
ricky
I'm not for sure but, there's a small engine oil cooler. I've seen these get a small hole and the high preasure oil will gladly go into cooling system. Then when you shut engine off, you have preasure in the cooling system. Guess where the coolant goes now.
Old Mar 9, 2007 | 07:40 PM
sdv515's Avatar
sdv515
yup, out of warranty. its cool how this stuff starts going wrong after 50k miles
Old Mar 10, 2007 | 07:02 AM
vano's Avatar
vano
Yeah, it almost seems like the manufacturers can engineer stuff to break shotly after warranty.
A little update:
I drove over the see Eric at Helix last night to look at my baby and talk about the next steps. He showed me the problem, put a stick into the coolant overflow and when he pulled it out, it was covered in what looked like melted cheese. Sticky, whiteish/brownish residue sitting at the bottom of my overflow. Eric is convinced it is oil... which makes sense. The good news is, he drained the oil pan, closely inspected the used oil and didn't see a single problem with that. He thinks the leak is one way - oil into coolant. No evidence yet that there is also a coolant into oil leak. Positive news I suppose.
Old Mar 10, 2007 | 09:24 AM
herbie hind
A little update:
definately check the heat exchanger . i sent my old one to a dude in thailand . it was kinda cool to write and send halfway around the world. but yup he had the same problem . and the exchanger was the culprit .
Old Mar 10, 2007 | 10:11 AM
amazonracer's Avatar
amazonracer
This is what I am afraid of
I don't know anything about head gasgets but going out at 54K miles is very concerning. Shouldn't the engine be working at its prime at this time. Again, hondas, toyotas, etc. seem to never have these problems at 54K. Maybe a Ford. I don't know anything about cars but why can one car company do so much better in dependability when it seems everybody as the benifit of the same technolgy. Is it a conspiracy. IMO, it appears it makes sense to get the extended warranty for my MCS 07. The work through your dealership being out of warranty even with some good news sounds expense considering a simple oil cange is $120.00. Can someone please give me words of wisdom because I really like this little car but I don't think I have the stomach for these kinds of problems.
Old Mar 10, 2007 | 12:25 PM
sdv515's Avatar
sdv515
this woman i know was telling me her head gasket blew on her bmw x5 at 54000 miles. it is definately a conpsiracy.
i also bought the car used so i have no idea what happened before i owned it. this could have been an ongoing problem. i'm going to check the dipstick right now.
Old Mar 10, 2007 | 12:27 PM
caminifan's Avatar
caminifan
Originally Posted by amazonracer
I don't know anything about head gasgets but going out at 54K miles is very concerning. Shouldn't the engine be working at its prime at this time. Again, hondas, toyotas, etc. seem to never have these problems at 54K. Maybe a Ford. I don't know anything about cars but why can one car company do so much better in dependability when it seems everybody as the benifit of the same technolgy. Is it a conspiracy. IMO, it appears it makes sense to get the extended warranty for my MCS 07. [Emphasis added.] The work through your dealership being out of warranty even with some good news sounds expense considering a simple oil cange is $120.00. Can someone please give me words of wisdom because I really like this little car but I don't think I have the stomach for these kinds of problems.
An extended warranty is definitely the peace of mind solution. While it is rare that a head gasket would fail (absent abuse), if it fails for you, it is a real pain. At that point, the $2,000+ that would have been paid for the extended warranty contract is peanuts in comparison to the cost of a short block engine swap.
Old Mar 10, 2007 | 12:32 PM
caminifan's Avatar
caminifan
A little update:
I drove over the see Eric at Helix last night to look at my baby and talk about the next steps. He showed me the problem, put a stick into the coolant overflow and when he pulled it out, it was covered in what looked like melted cheese. Sticky, whiteish/brownish residue sitting at the bottom of my overflow. Eric is convinced it is oil... which makes sense. The good news is, he drained the oil pan, closely inspected the used oil and didn't see a single problem with that. He thinks the leak is one way - oil into coolant. No evidence yet that there is also a coolant into oil leak. Positive news I suppose. [Emphasis added.]
Well, maybe good news if the heat exchanger is the source of the problem and there is no other damage. But the same scenario (oil into coolant) could occur from a cracked block, and I imagine you can understand that that would not be good news.
Old Mar 10, 2007 | 04:39 PM
herbie hind
that would suck. but there is a short block on ebay for short money . i'm no fan of ebay but it may be possible to have a magnefluxing put into the deal . you know return of money pursuent of positive test etc.
Old Mar 10, 2007 | 08:46 PM
caminifan's Avatar
caminifan
Unfortunately, the amount of effort you would have to do to completely confirm there are no problems with the eBay short block make it a questionable solution. Barring something simple like the heat exchanger or a blown head gasket (if there is no contamination of the oil), it sounds like a short block is in the immediate future. And I wouldn't use the dipstick as a metric for determining whether or not there is contamination of the oil.
Old Mar 11, 2007 | 06:53 AM
herbie hind
checking the dip stick and the filler cap are good off-hand ways to see if water is in the oil .
Old Mar 11, 2007 | 06:56 AM
herbie hind
i still say heat exchanger . i haven't seen one cracked block on this forum . with all the modding being done; guys running 600 hp . it's a testiment to the cooper block . (raises glass to cooper poster ) ; amen brother!!!
Old Mar 11, 2007 | 10:45 AM
vano's Avatar
vano
I would be shocked if the block was cracked, the enginer is 100% stock, haven't done anything to it - still 115hp come out of it. But I guess you never know. I trust Eric will carefully inspect all potential failures before putting the motor back together. He hopes to have the parts in tomorrow and get the work started on Tuesday.
I will give him a call and mention the heat exchanger, in case he hasn't already noted it as a potential root cause.
Old Mar 11, 2007 | 11:07 AM
caminifan's Avatar
caminifan
I am not saying that the block will be cracked; just that you shouldn't be surprised if it is cracked.
Blocks typically don't crack from heavy modifications to the engine; a block is more likely to crack from a failure of a part that is related to the cooling system and the engine continues to be operated while in cooling system failure mode. If the engine was operated for an extended period of time with no coolant, even a box stock block would crack.
Old Mar 12, 2007 | 05:43 AM
vano's Avatar
vano
Point taken, Eric asked me that same question as soon as he noticed the oil in my coolant... "did you have a major/extended overheat occur with your car?". My answer was no. I am pretty religious at glancing over and checking the coolant temperature. Is there a possibility that the engine overheated badly at some point? Yeah, there is always a chance that during one of my Evo autox classes with the adrenaline from back to back runs I wasn't as observant of the engine temps, but its very unlikely. Also, wouldn't a major overheat, one capable of warping the head and/or cracking my block manifest itself in a more obvious manner?
Old Mar 12, 2007 | 10:04 AM
caminifan's Avatar
caminifan
Point taken, Eric asked me that same question as soon as he noticed the oil in my coolant... "did you have a major/extended overheat occur with your car?". My answer was no. I am pretty religious at glancing over and checking the coolant temperature. Is there a possibility that the engine overheated badly at some point? Yeah, there is always a chance that during one of my Evo autox classes with the adrenaline from back to back runs I wasn't as observant of the engine temps, but its very unlikely. Also, wouldn't a major overheat, one capable of warping the head and/or cracking my block manifest itself in a more obvious manner? [Emphasis added.]
Not necessarily. The fact that your coolant recovery tank was bone dry could indicate that the engine was operated without enough coolant sufficiently long for the block to crack. I don't know if these cars have a low coolant level sensor or not (to warn that the coolant level is low). But even if they did (have a low coolant level sensor) and the sensor failed, you could have had the coolant level get progressively lower and lower until the head gasket blew and with continued operation, the block cracked. If your head gasket is blown, you have had something happen. The path from blown head gasket to cracked block is pretty short.
I don't want to sound pedantic, but I have never been one to completely trust electronic sensors. Which is why at each fill-up, I visually check the engine oil, coolant and brake fluid levels.
Old Mar 12, 2007 | 11:05 AM
Dr Obnxs's Avatar
Dr Obnxs
Now that's funny!
Yes, they too have early failures! I guess you didn't read about the Toyota engine warranty extension due to problems with sludge in too small oil galleys. A lot of motors cooked.
And really, this is where a course in statistics helps out. Out of almost 1 million cars produced, how many times does a problem need to show up for it to be considered a worry point? One? Ten? A hundred? A Thousand?
In mass manufacturing, there are always a few that are screwy, but not statistically a lot. The cost of making manufacturing perfect isn't worth the effort, and would really drive up the cost of cars a lot.
So rest happy, and know that no matter the car you buy, there's a chance that it could blow tomorrow. But it's not likely. There are so many other things to worry about that this one shouldn't take any metal capital. Not worth the effort.
Matt
