adjusting wastegate and bov
Old Oct 23, 2006 | 10:22 AM
Eastsidemini's Avatar
Eastsidemini
What is a way to find out if the wastegate is adjusted properly? what to look for relating to vacuum or boost?
Should the bov be venting a little at idle under vacuum? what is the proper adjustment on how much to vent or at what rpm?
Old Oct 25, 2006 | 04:21 PM
herbie hind's Avatar
herbie hind
you know ;i had no idea we had a blow off . i figured we had a finite amount of boost possible. i'll have to read up on that one.
Old Oct 25, 2006 | 04:56 PM
Eric_Rowland's Avatar
Eric_Rowland
If you're driving a supercharged MCS, you don't have a BOV, unless you've added a turbo. You DO have a BPV (ByPass Valve) which routes air around the SC when the engine is not running a vacuum (aka, moderate to heavy throttle.) Stock boost level is 10-11psi, IIRC.
Some have found that the BPV doesn't close fully. You can take it off and confirm it closes fully, instructions here.
Old Oct 25, 2006 | 05:25 PM
Eastsidemini
sorry
Sorry, I should have mentioned is for a TC car not a stocker.
Old Oct 26, 2006 | 01:54 PM
herbie hind
yeah i'm aware of the bpv . intimately lol . it's open while on vacuum low rpms then closes as vacuum diminishes and boost increases. therebye allowing us to save fuel at moderate driving . i ran the detroit but it wasn't my cup. so i put the oem back in though adjusted for full seal -no stick. best of both worlds .
vetsvette
Oct 11, 2015 06:05 PM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
Emnotek
Sep 29, 2015 07:37 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
