Mini Cooper Cylinder Head
Old Sep 3, 2006 | 03:32 PM
FinalUnity's Avatar
FinalUnity
Does anyone know if there is a diffrence in the Mini Cooper S and the regular Cylinder Head. I have the option of getting a 05 Mini S head for my 02 Mini.
My cooper is not an S type but the pictures look exactly the same.
Thanks,
Lou
Old Sep 3, 2006 | 03:38 PM
kurvhugr's Avatar
kurvhugr
I've been told (many times) that the only difference between the heads is the material the valves are made of.
Old Sep 3, 2006 | 03:39 PM
herbie hind's Avatar
herbie hind
check the part #'s with your local dealer.
Old Sep 3, 2006 | 03:43 PM
Rawhyde's Avatar
Rawhyde
What really matters is the combustion chamber volume, and I don't know if there's a difference.
The S has sodium filled valves, but I don't know if they're of a different size than the Cooper's valves. If the chamber volume is the same and the S has bigger valves, that'd be a cool upgrade.
Rawhyde
Old Sep 3, 2006 | 10:54 PM
kurvhugr's Avatar
kurvhugr
Rawhyde
The valves are the same size.
Old Sep 4, 2006 | 08:37 AM
k-huevo's Avatar
k-huevo
The only difference between the Cooper and S head is the valve material. The S’ valves are made from Inconel; for a general definition http://en.wikipedia.org/wiki/Inconel . The valve size is the same and all other parts in the head and valve train are the same. Compression is lowered on the S by a recess in the piston crown. The advantage to replacing the head would come from a re-work of the port geometries and other flow improving techniques while you have the other head. That way down time is reduced when you do the head swap.
Manny_cooper
17
Nov 1, 2024 07:46 PM
phrza81
Oct 10, 2015 11:37 PM
jrezzo
Aug 9, 2015 10:32 PM
Aug 7, 2015 05:56 AM
