type of oil
I know. I was surprised to see that BMW Castrol is actually a darn good oil. It's hard to make conclusions based off one car and one analysis, though. If I switch to Redline, I might do an anaysis after a couple changes (I've heard you get high wear #'s with Redline for the first couple runs because it's cleaning everything out). It's just hard to budget $20+ for an oil analysis at every change.
Another thing that you have to think about is if the oil can go 10-15k miles and still have a high enough TBN, can the filter go that far as well...would a filter-only change at 6k be the way to go??? That, too, would only be answered by testing and oil analysis.
I'd been alternating between factory oil (the free changes) and Mobil 1 until
the last change. I'd learned that Mobil 1 is no longer group IV but a mix of
group III and IV (more IV in the extended formulation), and was about to
go for Redline or Motul (both group V), but then noticed that a local shop
I drive by nearly every day had Amsoil (IV) on their shelfs, and went with
that this time.
I usually change every 5-7.5K (halfway between recommended intervals),
so it's probably a much of a muchness between the choices.
that this time.
Some on BOB are noticing Redline slipping in the cleanliness dept. lately.....right out of the bottle (seeing visibile particulates).
I've also noticed they have higher Iron #s in virgin analysis too.
I don't know, but I would stick with the BMW Castrol LL or Mobil-1 (in a pinch).
I use Mobil 1. Car companies actually have contracts with other companies wherein they will advertise a particular product (by recommending it) for some arrangement with the supplier. Movies do that, too. If you see someone drinking a Coke in a movie, it's likely Coke paid for that. Or bands, that put something like "Dave uses DW drums exclusively" on their cd.
There was a post on "Bob Oil Guy" about someone with a Cooper S using German Castrol 0w-30 and his iron wear numbers weren't that great as compared to his his previous BMW Castrol LongLife 5w-30 test numbers (5K interval for both). FYI, the BMW Castrol 5w-30 oil is not the same one you get at WalMart, AutoZone, etc. Notice the moly and additive package numbers on the BMW oil is very high even after 5K miles on it. It could probably go past 10K intervals if it weren't for possible fuel dilution issues.
http://www2.propichosting.com/Images/450001341/11.jpg
BOB link:
http://theoildrop.server101.com/foru...&Number=853636
BOB link:
Those on "Bob" are blaming my air filter. I'm not so sure at this point.
I went back to a paper air filter for this run and will see if the iron goes down. There have been more postings lately with high iron numbers with German Castrol, so maybe it's the oil.
Belgium has good refineries and good additve package
Royal Purple does an excellent job of protecting engine internals. I had outstanding results from my last 7,000 mile OCI analysis (5W30). Because of fuel dilute levels, the viscosity has been upped to 10W30, and I’m changing a few things about the tune.
http://www.lonestarminiclub.com/foru...read.php?t=411
Oil analysis is a good investment; a thorough report analyzed by an expert costs more than a cursory one but is far better than burring head in sand delusive thinking.
Redline discussion:
http://theoildrop.server101.com/foru...0&fpart=1&vc=1
http://theoildrop.server101.com/foru...131#Post787860
BMW LL Virgin Analysis:
http://theoildrop.server101.com/foru...e=5#Post474688
original MINI one:
http://theoildrop.server101.com/foru...e=0#Post853636
cub4bearindiana
Jun 30, 2016 06:11 AM
