Smoke on startup
Old Jun 16, 2006 | 02:03 PM
ThumperMCS's Avatar
ThumperMCS
Smoke on startup
Lately I've been noticing a little bit of smoke coming out of the exhaust when my car is started. It only happens when it starts though, never when idling/driving/accelerating, so because of that I assume that I have nothing to worry about...is that assumption correct??
Old Jun 16, 2006 | 03:02 PM
qwertmonkey's Avatar
qwertmonkey
Probably just the choke. I think. Mine does the same thing.
Old Jun 16, 2006 | 04:58 PM
Bigcoyote's Avatar
Bigcoyote
Hey there,
What color is the smoke???? If it has a blue tint to it ( oil smoke ) I would say that maybe your valve guides are leaking.
You normally only see it on start-up after the car has sit for a little while.
Good luck
Old Jun 16, 2006 | 05:24 PM
ThumperMCS's Avatar
ThumperMCS
There is no blue tint to it. Its just a "smokey" color...i guess you could say grey.
Old Jun 16, 2006 | 10:32 PM
Bigcoyote's Avatar
Bigcoyote
Hmmm...
Well as a rule the smoke color code is:
Black smoke = unburnt fuel
blue / white smoke that hangs around = oil
white smoke that dissipates ( like fog ) = water / anti-freeze ( also can smell sweet if anti-freeze).
several things can cause smoke - once you figure out what type of smoke it is - then you can find out where it is coming from.
Hope this helps
RobbyD
Jan 29, 2019 01:22 PM
pfcmooney
Jun 15, 2016 07:22 PM
micromini234
Sep 30, 2015 07:36 PM
jennster
Sep 28, 2015 06:19 PM
Jolio
Factory JCW Talk (2009+)
Sep 17, 2015 09:23 PM
