oily mini...
Old Mar 19, 2006 | 04:35 PM
glnr13's Avatar
glnr13
oily mini...
last night i was driving along sunset blvd on my way to dinner... anyhow, i heard a muffled "bump". almost as though i hit something. drove for 2 or 3 blocks and smoke started to come out from the bonnet. popped it open and there was oil on left side of the engine bay. i don't know much about my mini's engine/oil/etc... but i do know that it was engine oil. on another note, i went in for my oil change at 10000, had an oil leak immediately... took it back to my dealer and it turned out that the oil filter was faulty and it did not allow the cover to completely seal... they fixed it that day. i took it in yesterday because the "service" mileage was going backwards everytime i drove it (from 15500 to 15000, then 14775, then 14550, etc. it's now at 12775 and my actual mileage is at 13375.) The dealer knew of my previous incident and told me that the service count was receding because of the oil "cap off" from the fix... but they didn't actually look at the car. just told me to bring it in at 15500. Now here's my situation, maintenance is closed today so im taking it in tomorrow. but i was just wondering if anybody had an idea of what this is... thanks in advance...
Old Mar 19, 2006 | 10:45 PM
Barnabas's Avatar
Barnabas
Did you find out where the oil came from? Did something explode inside your engine bay?
I don't understand your coment with recedding service mileage...they're supposed to count down when you drove...oh the mileage you actually drive doesn't quite match the coutndown mileage due to other influencing factors like injector ontime, coolant temp, etc. Basically harder you drive, the SIA will count down faster.
Old Mar 19, 2006 | 11:08 PM
rottenron's Avatar
rottenron
counter
counter should start at 10000 & count down
Old May 26, 2006 | 07:02 PM
glnr13's Avatar
glnr13
here's what happened...
My motor mount went bad. oil was coming from the mount itself.
took it in and the dealer fixed it no questions asked. it took all day but bruce leeroy is happy again
as for the counter thing... im stupid. i didnt realize it was counting backwards.
Old May 26, 2006 | 07:54 PM
RAW_MCS's Avatar
RAW_MCS
on another note, i went in for my oil change at 10000, had an oil leak immediately... took it back to my dealer and it turned out that the oil filter was faulty and it did not allow the cover to completely seal... they fixed it that day. ...
I too recently had my scheduled oil change done @ the dealer... a couple of days ago while having my 19% pulley installed, Eric @ Helix observed some oil at the base of the oil pan... I'm really hoping that my oil leak is the same problem that you encountered, making for an easy fix... i'm setting up an appointment next week w/the dealer.
MotorOn,
Old May 26, 2006 | 09:23 PM
caminifan's Avatar
caminifan
Originally Posted by RAW_MCS
I too recently had my scheduled oil change done @ the dealer... a couple of days ago while having my 19% pulley installed, Eric @ Helix observed some oil at the base of the oil pan...[Emphasis added.] I'm really hoping that my oil leak is the same problem that you encountered, making for an easy fix... i'm setting up an appointment next week w/the dealer.
MotorOn,
You seem to be more casual in your maintenance than I am. I double check the maintenance to be sure the tech correctly installed the filter. The last thing I wold want is for the engine to get fried due to a maintenance lapse.
Old May 26, 2006 | 10:47 PM
RAW_MCS's Avatar
RAW_MCS
hhhmmmm... i hear what you're saying, didn't think i would have to double check the work of reputable BMW mechanics...
I do check the oil everyweek, the level is fine... i think it's more of a slight seep instead of a constant leak...
boholio
Nov 9, 2015 03:50 PM
silence2-38554
Sep 28, 2015 12:19 PM
mikem53
Off-Topic :: Autos
63
Sep 23, 2005 06:30 PM
inioway
Sep 8, 2003 10:00 AM
Danbo
Jun 25, 2003 12:36 PM
