limits of the steptronic
Originally Posted by Khodabear
This could be MINI Urban Legend, but, when my transmission guy and I were talking he asked if I had the MT or AT. I have the MT. Good says he - the AT's are failing at around 60,000 miles.
Seems a guy in San Francisco - admittedly hard use - bought a small fleet to use as courier vehicles - all with AT - and they're all suffering excessively high failure rates.
Originally Posted by ScuderiaMini
from a performance point, except the DSG transmissions, there is nothing faster than a MT, i even don't like the SMG.
Originally Posted by eVal
Just today I was out and about and had so much fun darting around going through the gears in my auto MCS I can only tell you that it is a very enjoyable and fun car, still has a lot of pep and great handling. (Fwiw I am in manual mode an flipping through the gears with the paddles most of the time, that's where the fun is for me - even managing paddle shifting through the curves as needed
The car in any incarnation isn't a mega horsepower sports car so I don't worry about it much in that way, a little lost 0-60 time has not been a factor in real world driving; using the gears and keeping it in the best revs is still possible in the auto so I think you'll enjoy it - you'll definately want to test drive one and wring it out first to get a feel for yourself though. If you spend a lot of time in your commute car you might as well get one you enjoy
Just a note, the car in auto mode is not nec the smoothest shifter from what some have said, so be aware of that and also test that out if you care about that. The thing is the tranny is adaptive so as I found the test drive is not as good as it gets, however it will give you some idea of how it can be in manual and in auto. As I said I use manual mode mostly, and when in auto I like the somewhat manual sensation of the gears shifting - and in any case its so much better then the jerky SMG in auto that its seems just fine - after all its not a Caddy, the car is about feeling all aspects of driving I think
Out of curiousity, you mention jerky shifts of the SMG (presumably SMGII?) in auto mode; do you recall which Drivelogic setting you were in? Higher (4/5) settings will be more "jerky" because shifting is optimized to keep engine revs up (especially noticed during down-*****). In the lower (1/2/3) settings, I haven't noticed jerky shifts.
Originally Posted by caminifan
I thought that DSG was the equivalent of SMG (up to just before the point of patent infringement)? Am I missing something?
If your "thing" is 0-60 mph, the MCSa is not for you. (Of course, neither is the MT MCS, for that matter.) The real fun of the car is running it through the gears and not having to ride the clutch in stop-and-go traffic. I would also submit that the MCSa handles every bit as well as a MT MCS (and can be modded in the handling department every bit as much as a MT MCS).
If you are experiencing downshift harshness, you might check into whether all of the factory service campaigns have been perfomred on the car. My MCSa was experiencing part throttle downshift harshness (such as when you are coasting to a red traffic light). After having the DME re-program service campaign performed, the harshness is pretty much gone (and when it does happen, it is much less harsh than before the service campaign).
). Dunno if it has improved over the years but then again, if you never had the better earlier programming you wouldn't miss it. Thank god it had SMG though, or they would have blamed the engine failure on a MT overrev. But that's another story told already ...
thats one thing i didnt enjoy is stop and go traffic and im in alot of it. i would rather be able to just relax and eat a hamburger than having to keep shifting gears for 3 hours to get a half a mile down the road haha. anyway you guys have been very helpful. now i just need to decide what all i want to do to the car. these cars are super cool
I searched the forums a few times and haven't found the info I'm looking for. I'd like to revive this thread (I know I know...) and ask about the limits of the steptronic in terms of modifications to the car. I'm curious for my own ideas with my car, but I am sure there are other people that might have similar questions.
* What modifications are NOT possible? (i.e. don't fit, not compatible, transmission cannot handle -if that's an issue)
* What modifications ARE possible? (i.e. exhaust)
* What modifications ARE possible, but require some different parts? (i.e. Alta Intake can't use the colored silicone tubes)
Thanks for the help
Thanks for the help
I take it since you mentioned the Alta Intake that you are talking about the MCSa tranny. I have installed most of the common mods on my MCSa and have since removed due to issues. All not related to tranny.
Pretty much all mods are the same and don't require much modification.
Superchager reduction pulley - Is a bit harder to install due to the engine being shifted over to accomidate the larger tranny.
Crank pulley - Same as supercharger pulley.
CAI - Alta has a new hose almost ready for the MCSa. I should have a prototype soon. But without the hose nothing different.
Exhaust/Header - Nothing special.
ECU - No company has come out with one specific to the tranny that I know of.
Head/Cam - Nothing special.
Intercooler - Nothing special.
Anyone else?
Anyone else?
I can truly understand the need for an automatic tranny in some cities... I personally feel you lose some of the driving experience with an auto, but certainly understand the need for one. My other car is an auto and used mainly for city errands.
Automatics usually can not handle much more power than for their original application. It is easier to beef up a manual tranny than an automatic.
So, has anyone contacted AISEN for info or looked into how the same tranny has been used in other cars? It may already have been proven to work with more hp in other vehicles - some autos are very robust (ie consider how Mercedes uses them in AMG applications) so it might surprise you if you get info from the manufacturer .
I've been looking at Mini's for two years and for the past year with some serious interest. I kept bouncing back and forth between the two (M vs Auto), but decided that I would just get an MSCa to play with for the next few years (tangent: looking to relocate to Japan in 3 years for a one/two year stint teaching)...so I figured for now I would just try to keep the price and the mods (avoiding JCW was so hard) to just enjoy the car and see what the future held.
Now I can't contain myself!
The urge to mod the car is tough to beat and the thought of garaging it for a year or two is sounding reasonable. So here I am...
As for the automatic not being able to handle as much power...that's where I get curious about the Steptronic and the power it might be able to handle. For example: SPI Twin Charger...out of the question, or reasonable?
...I was planning on spending some time this weekend doing some Steptronic research to see what I could find out.
Some of the issues of the transmission are not just related to the hardware but to the software. When I had a lightened crank pulley installed on my car it caused the car to not shift as it should. Meaning the car would rev so fast that the ecu couldn't properly calculate the shift points. Shifts in 1,2,3,4 would occur @ a increased redline of 7200rpm.
someone correct me if I'm wrong, but I believe that this transmission has been used in the 225hp audi TT.
in any case, for street applications, you have to question whether you would want much more power than this in a FWD car with no LSD.
i was thinking the same thing, but i have an 05 MCSa and i love it! i have raced manual MCS and have never been embarassed by the manual. i think people are afraid do drive the auto, as i was, but for me im always in stop and go traffic. but i just love it! the paddles are alot of fun too! but yeah, i beet manuals just was well as autos...so i see no problem. take one for a test drive and check it out for your self. dont get me wrong i love manuals, but after have all my cars manual, i decided i would go for the auto.
Awesome...that would be some good stats to have. Than again, I donno if I want to see my bill of the parts I'll order if the numbers come back more positive than I think
I talked with Tuls and Chad @ Detroit Tuned a little bit about the limits...I'm just trying to decide if I want to blow the car up just yet...I mean I just crossed over 2,000 miles
Originally Posted by mikem53
The autos used by AMG , vettes , etc are built to handle the torque for that specific application. The mini's space constraints make it difficult to modify and fit beefed up parts... Not saying it can't be done.... but more difficult for sure..
Just don't do what I did in my first MINI! Blow it up twice! Hmm, I would stay away from internal engine mods on a CVT. Don't use Steptronic all the time, as it tends to wear out quicker. Also be sure to check trans fluid if possible every 10k miles if you tend to have a lead foot like me. Basically thats all I can suggest. Goodluck!
P.S. Don't let my words worry you.
The autos used by AMG, vettes, etc. are inline configuration and do not have to work with the MINI's transaxle. The transaxle is the weak point. An inline A/T can be setup to handle north of 700 ft/lbs.
Originally Posted by WEEGIT
In the MINI's case as well as most other front drive cars, is it considered a transaxle when the engine and transmission are oriented transversely?
...What about Porsche and their true transaxles - no problems there handling gobs of torque.
RobbyD
Jan 29, 2019 01:22 PM
vulkandino
Oct 31, 2015 08:29 PM
Sep 28, 2015 09:13 AM
