Oil leak sources at 177k miles
Old Today | 07:59 AM
khnitz's Avatar
khnitz
I'm in the middle of preparing our Mini for the Summer and there are some extensive repairs underway.
I am in the process of replacing the valve cover gasket, which may or may not be original. My question: other than the valve cover gasket, what other oil leaks at the front (vehicle's front) of the engine would cause this amount of oil leaking and build up?
I'm in the process of degreasing that area now. I had serviced the supercharger oil <20k miles ago, but I'll check the level while I have access, too.
Old Today | 10:26 AM
Here2Go's Avatar
Here2Go
NAM Community Team
I'll preface by stating that I'm not nearly an expert as you.
(To me), It appears that perhaps you are correct - Valve cover was leaking a bit. Dip stick 'O' ring might need replacing. From my previous experience : The oil pan gasket maybe leaking at the front.(?)...
I replaced mine with Felpro. And it still leaked a little in some areas. But probably my fault - Although I followed the torque sequence; I replaced mine while on jack stands.
For me - It was a PIA.
Nice that you have the car on a lift!
Kingeresident
May 13, 2025 08:05 AM
jjcsnlynn
Apr 14, 2019 05:04 PM
jbourne
Sep 12, 2016 12:17 PM
dertef
Jun 10, 2014 02:33 PM
carterR50
Oct 17, 2012 11:11 AM
