Persistent 2EE5 dtc.
Old Jun 14, 2024 | 07:43 PM
  #26
RUPNOK's Avatar
RUPNOK
Yes, I have one. Do I connect to ground and touch the lead to the back probed orange wire and look for a pulsating light at operating temp? Will I be able to see it at the frequency demonstrated on your scope?
Old Jun 14, 2024 | 08:12 PM
  #27
mkov608's Avatar
mkov608
The DME is sending system voltage to the thermostat on the orange wire; it then completes the circuit by providing the ground via the white wire; when that happens, the circuit voltage drops to zero; When the DME disconnects the ground, to voltage goes back up to system voltage; in the previous lab scope picture, the scope was set to 50 milliseconds; so if you connected a test light to the positive battery terminal and then touched the tip to the back-probed white wire, the light should illuminate when the DME completes the ground circuit, but the pulses are so fast you will only see a steady light and only after the engine has reached operating temperature. Any good indy shop should have a lab scope and could tell you if the DME is switching the ground on and off; you've already verified it's sending out the power.
Old Jun 14, 2024 | 08:33 PM
  #28
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
I wonder whether a multimeter set to read frequency would be able detect the duty cycle frequency.
Old Jun 14, 2024 | 08:36 PM
  #29
RUPNOK's Avatar
RUPNOK
Could you recommend a scope that is reasonably priced for the diyer? As you can see, electrical is the weakest of my auto based skills
Old Jun 14, 2024 | 08:57 PM
  #30
mkov608's Avatar
mkov608
It can't. Not fast enough.
Old Jun 15, 2024 | 03:58 AM
  #31
Maybe, maybe not
Community Builder
Amazon Amazon
Old Aug 12, 2024 | 02:31 PM
  #32
Maybe, maybe not
Community Builder
Update? Problem fixed?
sleepingbrain
Apr 16, 2024 01:45 PM
redwhiteR562007
Apr 21, 2021 10:23 AM
mish
Apr 23, 2018 10:57 AM
mmdouglas
Feb 4, 2016 06:36 AM
DMB MINI
Nov 4, 2015 10:25 AM
