Problem with rear brake R & R
Old Apr 24, 2024 | 06:03 AM
JAB 67's Avatar
JAB 67
2004 MCS, original owner, 185K. I'm having a problem with the rear brake pad and rotor replacement. I have done this previously probably 3-5 times without issue, so I'm stumped. How exactly do you install the 'rear brake pad retaining spring?' I'm installing new pads, rotors, and the retaining spring. This time the spring rubbed on the rotor hub and the ends of the spring did not contact the pad carrier. In other words, its not accomplishing anything. Help!
Old Apr 24, 2024 | 08:20 AM
RockC's Avatar
RockC
Don't have any details to offer. Just that when I did brakes -- this on various cars over the years -- I would raise say both rear wheels off the ground and once the car was safely supported remove both wheels and expose the brake hardware.
Thus when I worked on one brake I'd have the other side to refer to if I had any questions on how to reassemble the brake hardware.
'course I was sure the brake hardware was correct as it was factory original or if I had done the brakes before to be sure I had the brake hardware installed correctly.
Old Apr 24, 2024 | 12:36 PM
mrbean's Avatar
mrbean
So it's a new spring or you're re-using the old one?
If it's new, hold it up to the old one to compare.
ofioliti
Tires, Wheels, & Brakes
48
Nov 18, 2023 11:30 AM
jamadeus
55
Jul 7, 2015 06:15 AM
uromini
May 15, 2013 06:01 PM
Wetworth
Oct 1, 2012 10:07 AM
SKL
Oct 27, 2007 07:19 PM
