2003 r53 all right turn signals not working.
Old Jul 27, 2023 | 07:56 PM
Margarita Man's Avatar
Margarita Man
Hi All.
I've seen some posts about this but most are quiet old and no solutions in there for me. Some were Left side....mine is Right side but right hand drive!
So.
​​​​​​Turn signal stalk works.
flash is at normal speed.
All indications in dash are correct.
Ticking from centre console.
No flashing on any of the exterior turn signals. all 3
Tried from a spare working car
Footwell module.
LIght stalk.
Center console
Steering console.
Bulbs checked.
No voltage to any indicatoRs.
Ohms test shows ground wires conduct to chassis.
All fuses checked.
no power to fuse 5 but same on 2 other working cars
Please help
Old Jul 28, 2023 | 07:28 AM
mrbean's Avatar
mrbean
The GM module controls the turn signals. It's fed by a multitude of fuses. I would start with checking them.
If you have a BMW/MINI scanner, I would also scan it for errors.
Old Jul 28, 2023 | 05:37 PM
Jordan Smythe's Avatar
Jordan Smythe
I've had lights burn out, and NOT cause things to flash, or throw an error. I'd check that first.
Old Jul 28, 2023 | 07:28 PM
JasonJasonJason's Avatar
JasonJasonJason
As per post.
Bulbs checked
Old Jul 28, 2023 | 07:29 PM
JasonJasonJason
[Thanks.
found fuse 5 has no power to either side of fuse.
Just dead .
Not sure if it's the panel or faulty or no input power.
Will investigate that next.
QUOTE=mrbean;4657527]The GM module controls the turn signals. It's fed by a multitude of fuses. I would start with checking them.
If you have a BMW/MINI scanner, I would also scan it for errors.[/QUOTE]
Old Jul 28, 2023 | 08:15 PM
JasonJasonJason
All fuses checked
[I checked them.
no power to fuse 5.
Checked 2 other working cars.......
All no power to fuse 5.
Old Jul 29, 2023 | 12:37 PM
mrbean's Avatar
mrbean
Fuse 5 on the panel in the engine bay or the panel in the footwell?
Either way,neither of those are related to the GM module- so don't worry about it.
I'd start scanning for error codes next
Brandon Fluharty
Mar 26, 2021 02:18 AM
sevin
Dec 7, 2016 04:29 PM
Fred's S Works
Dec 4, 2010 01:40 PM
lhyman
Jun 13, 2007 12:26 PM
