PO 2096 Trouble Code
Old Mar 11, 2022 | 09:52 AM
IDOXLR8's Avatar
IDOXLR8
Have something I can not fix. I have a PO 2096 and and after replacing the two O2 sensors can not reset the code. I read somewhere that not all scanners will reset the code. The code always show pending ,no matter how many times I rest with my scanner. Anyone around the 21074 area interested in helping out? I'm in the repair line but moved on to bigger vehicles (class 7-8 trucks)
Old Mar 13, 2022 | 08:30 PM
jjcsnlynn's Avatar
jjcsnlynn
I am in Dover, DE area and I have a Foxwell scanner. Let me know if you are in the area.
Old Mar 16, 2022 | 09:10 AM
IDOXLR8's Avatar
IDOXLR8
Po 2096
PM Sent.
Old Mar 16, 2022 | 10:42 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
2096 code is hard to reset unless you have inpa or itsa. It is a stored hard code. Only other way is it can take up to 20 engine cycles for it to clear. The main issue is your fuel trims are all out of wake. So the new sensors have to relearn you fuel trims. If you have inpa. You can reset your fuel trims an you are to go. If not takes a while to relearn.
Old Mar 17, 2022 | 09:06 AM
Soul Coughing's Avatar
Soul Coughing
P2096 can be more than just O2 sensors, but it's a good start. Did you check short and long term fuel trims? Have you checked the exhaust system for leaks? Checked the vacuum lines, bypass valve, and PCV for leaks? I downloaded INPA after continuing to get the code after resetting with with Foxwell scanner. Resetting everything cured my code, but I ended up replacing an O2 sensor at the same time.
speedman
Mar 3, 2020 06:30 PM
mrcolby321@yahoo.com
Oct 12, 2019 02:52 PM
Andrew Park
Feb 13, 2019 08:43 PM
