Very strange behavior even for a mini
Old Feb 3, 2022 | 07:44 AM
frankiev's Avatar
frankiev
03 MCS 162k miles . I stopped at a light when AC light started flashing and temp guage went all the way up to red but no cooling fan noise and didn't loose power steering . Pulled over expecting belt to be off or cooling fan issue but no steam or even very much heat . Cooling fan suddenly came on so I started the car and temp was normal ??? So it's obviously not overheating. what could cause this . Any help greatly appreciated
To be clear I'm also having what I believe to be a timing chain tensioner issue and Ive ordered one
https://www.northamericanmotoring.com/forums/stock-problems-issues/358953-valve-train-noise-on-start-up.html#post4612291
Old Feb 3, 2022 | 08:25 AM
cooper48's Avatar
cooper48
Maybe an electrical grounding issue causing gauges to malfunction? Check all your main ground terminals. MINIs are also notoriously prone to weird electrical issues if the battery is weak. Might want to check that also, especially now that it's cold.
Old Feb 10, 2022 | 06:31 AM
frankiev's Avatar
frankiev
I noticed I was low on coolant , once I refilled it and problem went away . Then today happened again and once again coolant was low . I believe the false overheat was due to no coolant by the temp sensor
Obviously I have a leak somewhere . I'm not burning it and I don't see any leaks so I need to pressure test. Anyone know how to pressure test with an aftermarket metal tank with a screw on cap
Old Feb 10, 2022 | 06:50 AM
frankiev's Avatar
frankiev
Found the issue . Apparently the head gasket is allowing coolant into the oil . Nice milkshake on oil cap bottom . I'll post a new thread
devinw
14
Feb 18, 2014 10:04 AM
buckeye_hunter
Oct 24, 2013 07:00 AM
BoostCzaR53
Jul 9, 2012 11:38 PM
Sisith
May 22, 2010 04:58 PM
Mike Storniolo
Oct 20, 2008 07:10 PM
