Mini won’t start
Old Oct 1, 2020 | 07:51 AM
Sam Peck's Avatar
Sam Peck
Mini won’t start
For the last few weeks, my MINI(‘06 R52 non-S) hasn’t been starting. I had a new Bosch starter installed about a month ago. The battery is August ‘19 but I also bought a new battery and that did not work.
IMG_3236.MOV
when the key is turned to the crank position, a humming or buzzing noise can be heard from the engine bay and only stops when the key is turned to the off position.
IMG_3237.MOV
my mechanic isn’t sure what to do, he found a bad battery cable so he installed a tandem battery cable from a BMW.
the only way I’ve been able to “reliably” start the car is with a push start(5-speed) but that’s very hard because I’m a 110 lb very small man. At this point I have no idea what to do.
Old Oct 1, 2020 | 07:56 AM
ssoliman's Avatar
ssoliman
What happens when you turn the key to start?
Old Oct 1, 2020 | 07:58 AM
Sam Peck's Avatar
Sam Peck
I get that buzzing noise as well.
Old Oct 2, 2020 | 04:01 PM
ssoliman's Avatar
ssoliman
If you can push start it your problem is with;
battery
circuit to starter (bad ground maybe)
bad starter
I’d start checking wire connections and cleaning checking grounds...
have the battery load tested at auto zone (free)
or find another Indy shop
valvashon
How to
96
Jan 30, 2024 11:56 AM
JayR52
Jul 18, 2017 09:11 AM
moogleslam
Apr 19, 2011 06:00 AM
harhoosh
Jul 30, 2007 10:43 PM
