2009 Cooper S FRM Module
Old Sep 1, 2020 | 01:26 PM
MiniKing11's Avatar
MiniKing11
Hi guys, I need some help.
So my driver side window doesn't always go up and down and BMW showed me it's my FRM module which previous owner removed a wire from the harness and drilled into the FRM and attached the wire directly to the module and then wraped the module in a bag. I assume water must of corroded the wire and they are trying to prevent it from happening again.
I think I should just replace the whole module. Is it possible? I guess I'd need harness pigtale. Are all FRM modules from 2009 mini coopers the same, or do I need to match numbers? Pig tails should be the same too no?
Any help would be awesome.
Old Sep 2, 2020 | 06:19 AM
MiniToBe's Avatar
MiniToBe
The safest approach is matching the part number, if not then match by car options/type specially headlights. the pigtails might be the similar but again watch out for headlight type.
what is the part number on your module and is it FMR3? I might be able to clone it for you.
Old Sep 2, 2020 | 04:02 PM
MiniKing11's Avatar
MiniKing11
Sorry, I contacted my local mechanic, he told me which numbers to look for, already ordered the FRM...I think it's an FRM 2...does that make sense? What's the difference between FRM 2 and 3?
cerenkov
Electrical
Dec 30, 2014 06:56 PM
romulus
Electrical
Jun 5, 2012 04:47 PM
MiniPOLACK
Electrical
Mar 26, 2012 07:55 AM
n559br
Electrical
Mar 8, 2010 04:49 AM
AC_MINI
Sep 16, 2003 03:19 PM
