Fan with a/c question
Old Jun 19, 2020 | 10:54 AM
idickers's Avatar
idickers
I have a 2002 r53 MCS with an a/c system that is not cooling well. It has good high/low pressures when I check with a manifold, but the air out the vents is not cold. I noticed that the electric fan cycles on and off when the a/c is running; should the fan run constantly with the a/c activated?
Old Jun 19, 2020 | 02:43 PM
MVPeters's Avatar
MVPeters
Fan - pretty much yes in heavy traffic - on the highway probably not, but it's hard to tell.
I have an early '02 R53 with manual heat & A/C controls. I find it difficult to get the distribution right but once I do, it's not too bad - just not the greatest.
Some folks say it's better on recirc - I haven't tried.
Old Jun 19, 2020 | 09:29 PM
Eric_Rowland's Avatar
Eric_Rowland
If the AC is on, tee fan should run on low. Can you tell if it's going from high to low, or low to off? If it turns off, likely your compressor is shot. If that's the case, time for a new compressor (first confirm your low speed fan is working.)
Old Jun 20, 2020 | 03:32 AM
idickers's Avatar
idickers
I can check the fan. I think the compressor is okay because I had a pressure differential; 45 on the low side and 225 on the high side, on a 90 degree day with humidity.
Legolover1076
Jan 15, 2017 06:02 PM
patsum
11
Aug 24, 2016 09:44 AM
rackops51
Dec 27, 2011 01:53 AM
dmcmonigle11
Sep 15, 2010 08:23 PM
phillyunderworld
Mar 8, 2007 06:55 PM
