Exterior door/window trim
Old Feb 13, 2020 | 06:56 AM
cooper48's Avatar
cooper48
I need to remove the chrome strip at the top of the door (bottom of window, above the handle) to correct a small dent. I thought it simply pulled straight up but mine will not dislodge. Is there a trick?
Old Feb 13, 2020 | 08:15 PM
ssoliman's Avatar
ssoliman
Which trim? Pic will help
Old Feb 14, 2020 | 07:45 AM
cooper48's Avatar
cooper48
Trim
Here's a pic of the trim piece:
Old Feb 14, 2020 | 05:23 PM
ssoliman's Avatar
ssoliman
Ahh I see. I’ve done the top trim on the roof, but not this one
hope someone here knows and chimes in
i usually search YouTube
Old Feb 16, 2020 | 08:53 AM
Zsm's Avatar
Zsm
The door trim does indeed pull straight up. It has clips that grip the top edge of the door.
Start from the end above the door handle and slowly work towards the front. Probably stuck a bit due to time and maybe some dirt.
Old Feb 20, 2020 | 10:27 AM
Yep, its tight on the door. They pinch on the door and with a trim tool kit I seen them stick due to being installed on a new paint job on a door panel and they installed them nd did not let the paint cure for days.
https://www.ecstuning.com/b-genuine-...t/51337071670/
Old Mar 11, 2020 | 06:04 PM
Aindrid's Avatar
Aindrid
One thing to watch for is those plastic caps at the end, they break easily. I rolled down the window and started from the door handle side. If you still have issues, pulling the door panel might help, it's 4 bolts (1 behind the reflector, mine was missing)
Mod Mini on youtube has great vids, heres one for the window reg replacement and he shows how to pop the trim off here:
Savannar98
Aug 22, 2019 11:27 AM
backsidedriver
Nov 2, 2014 05:35 PM
julesagogo
Dec 15, 2010 07:23 PM
mini552
Oct 14, 2006 11:24 PM
