2004 R53 won’t rev past 3k rpms
Old Feb 7, 2020 | 10:02 AM
Nick Smith's Avatar
Nick Smith
I have a 2004 R53 no lights are on other than the air bag light from steering wheel install I did. Car runs perfect and sounds normal other than it stops at 3k rpm. Drove the car to work which was an hour drive and no issues and no lights just won’t go past that mark. Any help would be appreciated
Old Feb 8, 2020 | 08:52 AM
DeadErnie's Avatar
DeadErnie
I'd start by checking your fuel pressure or your vacuum lines for the fuel pressure regulator. Could have a cracked/leaking vacuum line, fuel pressure regulator or fuel pump could be bad.
Old Feb 8, 2020 | 09:05 AM
Nick Smith's Avatar
Nick Smith
Thank you I will check all that out and see if anything is bad
Old Mar 22, 2020 | 12:07 PM
Nick Smith's Avatar
Nick Smith
Still no fix
I found a crack in the air intake duct that connect the throttle housing to the supercharger I fixed it but still the same issue
Old Mar 22, 2020 | 12:29 PM
user 7389739's Avatar
user 7389739
Could be supercharger bypass valve. Similar symptom, no power past 3K rpms:
Old Mar 22, 2020 | 05:59 PM
Nick Smith's Avatar
Nick Smith
Ok so only fixed it for a couple days don’t why or what’s wrong anyone else had these issues of running perfect til 3k rpm then it stops. I have replaced both map sensors, throttle body, 02 sensors, crank pulley, bypass valve, and hooked up to scanner to log while driving nothing looks wrong and no codes are shown just won’t go pay 3k rpms
Old Oct 13, 2024 | 04:06 PM
Josh_hoehn's Avatar
Josh_hoehn
I’ve been having the same issue with my car, was wondering if you ever were able to find the cause of the problem.
Old Oct 13, 2024 | 04:42 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Possibly a slipping belt or...
If your Mini still has the factory (OE/OEM) rubber core crank pulley - it could possibly be that the center rubber core has split from the outer metal portion where the belt rides.
In this case - the two halves are separated causing the crank to spin but not the belt.
EDIT: BTW - from my experience; A faulty or failing crank pulley or slipping belt may not show up as a fault with an OBDII reader.
Old Oct 14, 2024 | 01:18 PM
BRGPA's Avatar
BRGPA
Does it refuse to rev past 3K in lower gears as you try to accelerate or only when speeding up from top gears? A plugged converter could restrict the engine from speeding up. Or something as simple as a carpet (or something else) stuck under the gas pedal.
JrMC40
Jul 24, 2017 02:24 PM
pcowan13
May 16, 2016 05:18 PM
2004R53
Feb 10, 2016 12:04 AM
grizzlefry19
Jul 24, 2015 09:25 AM
