2008 R55 N14 HPFP weirdness..
Old Oct 21, 2019 | 10:40 AM
fast911ray's Avatar
fast911ray
My R55S displayed all symptoms of failing HPFP..Set point value of 0.00 bars. Installed a new aftermarket pump, same reading. Installed two more..remans this time...same symptoms and set point value of 0.00 bar. I've replaced every sensor there is with new oem, but still have the problem. Any thoughts or suggestions will be greatly appreaciated. Is there a way to adjust the set point pressures?
Old Oct 21, 2019 | 12:26 PM
MiniToBe's Avatar
MiniToBe
did you check the fuel rail pressure sensor?
Old Oct 21, 2019 | 03:28 PM
FastBlack330Coupe's Avatar
FastBlack330Coupe
Yes I did, and pressure is in spec as I recall. I'll do a recheck tomorrow to be sure.... the regulator is new.
Old Oct 22, 2019 | 05:49 PM
FastBlack330Coupe
The pressures are as follows:
Actual rail pressure: 0.87 Kpa
Rail pressure Set Point: 0.00 Kpa
Adapter value: 0.97 Kpa
Duty Factor fuel control value: 0.00 Kpa
And these are the codes currently displayed:
27CF Not Present, Fuel Supply System
27CE Fuel Supply System
28EE Fuel Pressure Plausibility
2880 High Pressure System
2F07 Present, Map Tstat Mechanism
MAF, MAP, Thermostat, Fuel pressure & Temp sensors are all new OEM
Old Oct 29, 2019 | 07:33 AM
Richieb0y28's Avatar
Richieb0y28
Mini had a service bulletin on this, check with your dealer
File Type: pdf
Old Oct 31, 2019 | 07:19 AM
fast911ray's Avatar
fast911ray
..but we installed a new aftermarket, then two OE rebuilt pumps yet the pressure readings/fault codes are the same.
Old Oct 6, 2022 | 08:21 AM
baileyboy2008's Avatar
baileyboy2008
did you ever get to the bottom of this mine is the same.
Deaconedgar
Jun 6, 2019 05:41 AM
MiniToBe
Feb 23, 2017 05:35 AM
MiniToBe
R55 :: Clubman Talk (2008+)
Feb 22, 2017 10:08 AM
BigBoost
Apr 24, 2016 04:53 PM
