R56 Hatch overheated now error. Blown head gasket?
Old Sep 6, 2019 | 01:52 PM
sonofray's Avatar
sonofray
Hello and thanks again for all the useful information and discussion here from you all! I'm at a crucial point of getting rid of my beloved MINI or not and need your help:
Recently, my 2007 R56 Hatch Mini Cooper overheated - I got the yellow temp light, then the red one, and the car sputtered to a stop. After diagnosing what the lights even meant, I checked the coolant level and sure enough it was empty. I walked and got some coolant nearby and poured it in. Most of it went straight through the system to the ground - I had a hole in my radiator hose from it touching the exhaust - but enough stayed in to allow it to start up and I drove it home slowly.
On a subsequent day, I poured more coolant in, started it up (easily), got no dash lights and drove it slowly to my mechanic. Occasionally during the trip, the yellow (or rarely the red) temp light would show. I would stop, pour in some more coolant, wait a minute or two, and drive it further on the path to my mechanic. As I finally got there, it sputtered to a stop again and died (similar to the first time).
My mechanic replaced the radiator hose (and fixed a problem with the AC), and it starts up now, but won't stay running without accelerating/getting the RPMs up. It gives the following codes - P0304, P0303, P0300. (3rd and 4th cylinder misfire). He's replaced the spark plugs and swapped ignition coils to see if they were part of it, but nothing changed. His final diagnosis is a blown head gasket.
Are there any ways to determine absolutely if it's the head gasket? Are there any other issues it could be/anything left to try?
If indeed it is a head gasket, this will be the end of my Mini, unfortunately. I simply don't have $1,000 - $2,000 to put in a 12 year old car that has lots of other little problems too.
Thanks again, everyone.
Old Sep 6, 2019 | 05:07 PM
gresh's Avatar
gresh
Thankrs again, everyone.
i just purchase a 09 MCS that the previous owner had the same problem. In this case, the head warped from the heat, so blown head gasket and a warped head. You can do a compression test with ALL of the spark plugs out. If the head gasket I'd blown or the head warped, it will leak into the other cylinder.
I honed my head myself using a perfectly flat marble slab with 80 grit sandpaper glued to it. I was able to get the warping out with about an hour of just pushing the block back and forth over the sandpaper. Polished it up using 220 grit. Now the head is perfectly flat. Since I pulled the head, I have to replace the head gasket anyhow. Total cost is $60 for the head gasket and $12 for the sandpaper.
Hambrick
Jan 15, 2017 06:28 AM
RocketUSA
Oct 2, 2016 06:57 PM
silence2-38554
Sep 28, 2015 12:19 PM
kurt112345
16
Oct 4, 2012 10:35 AM
03miniS
Dec 26, 2010 07:32 PM
