Anyone use this cheap ebay wind back tool (cube shape)?
Old Dec 26, 2018 | 12:19 AM
Subw00er's Avatar
Subw00er
https://www.ebay.com/itm/123523381028?ul_noapp=true
I was thinking of trying it.
The vendor can not confirm it works.
Old Dec 26, 2018 | 04:22 AM
RudeJoe's Avatar
RudeJoe
I’ve got one that I’ve used on Honda rear brakes for years. I tried it on my Mini when I needed to work on the rear brakes and it didn’t work. I just couldn’t turn the piston back in like on Hondas. I bought the brake caliper kit from Harbor Freight to do it. It requires a balance of pressure and turning to get the piston to retract. I think Autozone lends this kit out also.
Old Dec 26, 2018 | 03:58 PM
megaDan's Avatar
megaDan
I've had this for a few years now and is one of my favorite brake related purchases. It makes work so much easier. Skip the cube.
And I should add that I don't know if the cube will work or not, I understand everyone is on a budget, but sadly I can't help with OP's question.
Old Dec 26, 2018 | 04:36 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
I've got a cube that I've had for years. You can make it work on a MINI but you'll need to use a Dremel or similar tool to grind the "posts" on the closest set so they will fit into the rear brake adjusters. Once ground down properly, it just takes a little practice to make it work. For the few times it's been used, I've gotten my money's worth out of it.
Old Dec 26, 2018 | 08:38 PM
Subw00er's Avatar
Subw00er
ah, i Forgot about autozone rentals. ill just do that. Thanks guys
Old Dec 28, 2018 | 09:13 PM
Husky44's Avatar
Husky44
Haven't had the opportunity to use one on a Mini yet. I've used it on Mustangs. If your calipers are in good shape, nice and clean, and well serviced, you can make it work. But if they are at all crudded up or sticky, you're going to find it very frustrating.
Old Dec 29, 2018 | 08:28 AM
shrevemini's Avatar
shrevemini
Top Answer: 1
Just go to autozone an rent the right tool. Like 60 dollar deposit . An get that back when you are done. Just did it last week. Makes it super easy.
Gatorlapis
May 23, 2021 04:06 AM
flav
Off-Topic :: Autos
61
Jun 4, 2009 03:54 PM
ssallykat
DC Metro MINIs (Archive)
36
Sep 19, 2006 10:27 AM
Bydgoszcz
Tires, Wheels, & Brakes
12
May 30, 2006 08:25 PM
