Removed CAT and found these? What are they?
Old Dec 23, 2018 | 03:31 PM
jjcsnlynn's Avatar
jjcsnlynn
I was draining coolant (came out green) while removing the Catalytic Converter. I removed the 4 bottom bolts then the top 3. As I was pulling it up the bottom brackets fell into the pan. When I reached into the coolant for the brackets I found these.
What are they?
Old Dec 23, 2018 | 03:42 PM
jjcsnlynn's Avatar
jjcsnlynn
I think I know. When I took off the vacuum pump I accidentally took off the outer cover and something fell down. Could these be the inside pieces to the vacuum pump? There are two of them.
Old Dec 23, 2018 | 07:08 PM
I like mini clubman's's Avatar
That's exactly what they are. They are part of the rotary vane that creates the vacuum. They slide around the inside of that cap with the vane holding them in place.
Markbett
Jul 31, 2019 06:57 PM
Tweedbean
Mar 12, 2016 05:06 PM
jazztronikk
Sep 20, 2010 02:10 PM
dustinhxc
Oct 13, 2009 06:05 PM
002
Mar 26, 2006 06:44 PM
