I just got blasted with 8 fault codes
Old Aug 31, 2018 | 02:11 PM
JoeyF's Avatar
JoeyF
Im working on my project 2004 MCS. It has been sitting unused since December 2017. It was real cheap and i am slowly getting it back to road worthiness.
I had an issue before where the #3 fuse in the engine bay was blown. Replaced the fuse and cleared the codes and everything was peachy.
the light came back on and i now have these codes. That #3 fuse is good.
Does anyone see a pattern here? Maybe some real simple fix?
thanks in advance
Old Aug 31, 2018 | 03:41 PM
Minidogger's Avatar
Minidogger
I would check/clean all grounds before doing anything else.
Old Aug 31, 2018 | 04:30 PM
JoeyF's Avatar
JoeyF
Ill check the grounds tomorrow.
i found that the tube going from the airbox to the throttle body was unhooked from the throttle body. I put it back on then went and cleared the codes. They immediately came back. Surprisingly the car did not run any better... i am getting a hesitation when i push the throttle.
engatwork
Apr 25, 2015 10:56 PM
giantjoe
Dec 7, 2007 09:58 PM
rkw
Sep 17, 2005 04:05 PM
Col.Bobby
Jun 29, 2005 06:37 AM
PMC
Apr 30, 2004 10:18 AM
