2008 Clubman Oil Consumption
Old Jul 7, 2018 | 04:28 PM
CASmitty's Avatar
CASmitty
Having looked online for this issue and finding nothing, I thought I'd reach out to the experts here. My Clubman has about 105K miles and runs very well - except that it needs a quart of oil approximately every 200 miles. It doesn't leak, and it doesn't smoke. It appears that the missing oil is ending up in the catalytic converter and has to date ruined two cats. My mechanic replaced the valve seals to no avail, and now recommends replacing the engine and, of course, the catalytic converter.
Has anyone heard of anything like this?
Old Jul 8, 2018 | 03:24 AM
mustangcruise's Avatar
mustangcruise
I had a similar issue and mine was bad rings. A leak down test will help figure out the health of the engine.
You may also have an issue with a bad PCV valve.
Old Jul 26, 2018 | 09:37 AM
bugeye1031's Avatar
bugeye1031
Moderator
mustang is right....also, if your mechanic doesn't have lots of MINI specific experience, you might consider find someone who does.
Old Jul 31, 2018 | 03:11 PM
DneprDave's Avatar
DneprDave
This ^^^^
A bad PCV valve will cause oil consumption. This is located in the head cover and it cannot be repaired, you have to get a new head cover.
Old Jul 31, 2018 | 03:59 PM
cornjuice's Avatar
cornjuice
if the oil is in your cats.. its your turbo
Old Jul 31, 2018 | 04:12 PM
DneprDave's Avatar
DneprDave
The turbocharger is easy to check, just remover the rubber hose on the inlet and grab the center of the compressor wheel, it should spin freely and have no play axially or radially. Our MINI's turbochargers have no oil seals, they rely on close tolerances in the bearings to prevent oil leaking by.
Hairy W Bush
Jan 15, 2018 05:31 AM
ladzio
Nov 16, 2015 03:32 AM
timski
Mar 8, 2015 11:17 AM
bmwr606
20
Aug 4, 2012 02:33 PM
