Dave
Old May 24, 2018 | 11:54 AM
dadsr53mini's Avatar
dadsr53mini
Dave
Hello,
I am getting two codes (5E16 CAN Connection to instrument cluster) and (5E19 CAN data fault from DME/DDE (DSC lamp on as long aserror is present)). I do have a wheel speed sensor code for the right front wheel and that is getting repaired. How do I correct the CAN error codes? Any help would be greatly appreciated. I have an 06 R53 Mini Cooper S.
Old May 24, 2018 | 12:19 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
does the tach work? if it's not working check the wiring harness on the drivers left foot, it's below the fuses if the car has a sunroof you may have had the sunroof drain leak down onto that harness it's a very common issue
Old May 24, 2018 | 12:23 PM
dadsr53mini
The tach works and the vehicle does not have a sunroof. I will check the wiring though to see if there is an issue there, thanks for the reply.
Davbret
Feb 5, 2003 07:14 AM
LizzyBobio
11
Oct 17, 2002 09:30 AM
