07 r56 base model cooling fan issue
Old May 18, 2018 | 11:57 AM
hamilton8998's Avatar
hamilton8998
The car belongs to my daughter and wound up in my possession because Daddy fixes everything. I'm not a professional mechanic but I repair and maintain my own stuff (cars trucks boats motorcycles I love motorcycles
The car had a nasty oil leak,coolant leak,and would over heat with a coolant temp of 220f (acording to my scan tool) with no cooling fan activation , the engine would start cold and run fine then begin to run rufff and die at idle when engine temp neared the 220f mark. I've made these repairs as needed, Oil leak..Reseal oil filter housing, Coolant leak..Crack in radiator replaced with new one. Now the real problem..Over Heating,It was determined that little to no coolint was flowing thru the system, my experence tells me there are 3 items that can cause a no flow issue so all 3 were addressed....system flushed, new water pump and thermostat housing with new
temp sensor? i think. please correct me if im wrong.BTW nothing wrong with the WP and BINGO problem solved....well kinda sorta.The car runs great everything seems to work as it should except the fan which will run with AC on but will not as needed to cool the engine.I've checked the odvious things relays,fuses.There are 2 relays and 2 wires to the fan so i assume a 2speed fan?controlled by relays? 2 seperate circuit's ? I'm out of ideas and starting to over heat my self.any input is welcom thanks in advance
Old May 18, 2018 | 12:36 PM
MVPeters's Avatar
MVPeters
From your description, I think it's the low fan-speed resistor that has failed.
It is a very common problem.
There are literally hundreds of posts on this forum.
The fix depends on year & model but usually involves splicing a new resistor into the wiring - not much dismantling involved.
You could start here:
https://www.northamericanmotoring.co...early-r53.html
but there are lots more!
boiler up
How to
123
Aug 23, 2024 07:39 AM
reecekt
Aug 7, 2017 08:21 AM
RudeJoe
Jun 21, 2017 06:11 PM
reecekt
Sep 13, 2016 02:38 PM
andrew
Aug 6, 2002 06:40 AM
