06 mcs hesitate during gentle acceleration
Old Apr 27, 2018 | 05:25 PM
broost's Avatar
broost
hi folks,
06 cooper s 178,000km.
on highway or at constant speed, if i gently accelerate, i fell that the car hesitate like there was a tennis ball Under the pedal ( .. yeah yeah, i checkd. and its all fine Under it loll) , and Under full throttle at low rpm, i can hear a slight pinking .
other than that no codes. drives fine, idling is stable..
to fix this , i recently changed : oïl ( liqui molly 5-30 + oïl filter ,colder spark plugs, coil, dt.bpv, k&n drop in air filter, 17% pulley. and planning on doing the fuel filter this weekend..
anything else comes in your mind?
tought it could be the harmonic ballancer.. or the tps having a weak spot ( but it does it at all pedal ranges. )
thanks for your help !!!
Old Apr 28, 2018 | 05:00 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving you to the Stock Problems/Issues area.
Have you checked to see if you have any leaks around the throttle body/BPV area?
Old Apr 28, 2018 | 02:19 PM
broost's Avatar
broost
i made sure to clean / tight all bolts correectly. and the problem was present before i change the bpv ( the original one) so its the reason i changed it to a dt bpv.
i can double check during the weekend. i wouldnt thow a CEL ? if there was a leak?
Old May 8, 2018 | 11:45 PM
broost's Avatar
broost
bump.
changed the fuel filter.. feels better on pulls,
but still.. the problems stays.
Old May 13, 2018 | 12:13 PM
jjcsnlynn's Avatar
jjcsnlynn
I have something similar, but its been that way since I got the car used. It seems to be the pedal or throttle body with dead spots. I had a fellow MCS owner drive and he couldn't feel it but since I drive slower, I feel it.
Fike
Apr 23, 2013 12:37 PM
grudkin
Jul 25, 2012 08:43 AM
minitromag
Oct 1, 2011 10:30 PM
MiniMitchJCW
Factory JCW Talk (2009+)
20
Aug 22, 2011 06:44 AM
