2002 R50 Tach LEDs not working
Hi, Starting a new thread on this issue.
My Tach is functioning, turn signals work but LED display is out (2 tiny pixels in upper left only). Hence I can't do an ECU reset or see gas milage etc.
Does this sound like a bad TACH? and would replacing the Tach with a new/used one do the trick? Anyone ever experience this "no LED" situation?
Fuses look ok, but not sure about wiring.
thanks for any help :-)
Hi, I'm revisiting this thread I started some time ago. Has anyone experienced a fix for the R50 Tach LEDs not functioning? Might this require a replacement tach unit? Or does this sound like wire harness issues? Cant do an ECU reset with the tach lights out. Thanks guys.
We are in the age of digital imaging where one day of photos taken outnumber of a year's worth only a decade ago.Sound to me your dot matrix display is kaputt, not LEDs that you represented. If all these dots are dead except the two, obviously you won't see a change by resetting the ECU. Bad tach or bad tech.
Post a photo!
Mar 19, 2014 12:53 PM
May 2, 2013 02:29 PM
Interior/Exterior How to activate LEDs in tach gauge?
heyitzsushiboi
Feb 3, 2008 04:55 AM
