6 speed transmission bearing replacement
Old Oct 24, 2017 | 09:43 PM
Blowntranny's Avatar
Blowntranny
Has anyone put bearings in a 2002 6 speed manual transmission.
Looking for some suggestions / tips / tricks to take it apart and have the bearings pressed in.
Thanks.
Old Oct 25, 2017 | 07:42 PM
Montana Miniac's Avatar
Montana Miniac
Unless you have the special tools etc. I would suggest you look into a exchange trans from BMW with a full warranty.
Old Oct 26, 2017 | 12:32 PM
Blowntranny
Thanks Montana -
I pulled the case apart, but as you mentioned..looks like I would need some special tools.
Old Nov 3, 2017 | 10:14 PM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
Any ideas what kind of special tools are necessary? I have a blown gearbox sitting in my backyard!
Old Nov 12, 2017 | 06:47 AM
Blowntranny
Not sure exactly what is needed. At a minimum, some of the bearings are pressed against the case, so there needs to be some special tool to remove the bearings/races.
