06 p1125
06 p1125
So my 06 mcs (6 spd manual) has been throwing a p1125 intermittently (with no other codes,) obviously it goes into limp in.
My opinion is that it is one of two things:
1.) worn contacts on the throttle position sensors - hence it needs a new throttle body
2.) bad contact in the electrical connector or wiring harness problem.
My questions are:
Who has had this happen and what was you fix?
If you replace the throttle body how do you relearn the adaptives (limits of the throttle body) in the ECU?
thanks
My questions are:
thanks
Both the throttle body and wiring harness are failure points, but the throttle body was a much more prominent problem than the harness.
I've also run into situations where the connector just didn't make proper contact when it was plugged in and just needed cleaned out and reinstalled.
