Can this be welded??
Old Sep 27, 2017 | 07:07 PM
jfrankjr's Avatar
jfrankjr
Mystery exhaust leak
I am trying to track down an exhaust leak. I took it to an exhaust shop and he said it was the manifold gasket as there was soot on the heat shield directly above the gasket. I replaced the gasket but the old one wasn't leaking. I attached a pic to show where the soot is on it. It's around the edge if the gasket on the manifold side. No soot is on the engine side of the gasket. There is no soot on the manifold itself. The leak is still there so replacing the gasket did nothing. Any ideas where it can be coming from?
Old Sep 28, 2017 | 07:27 PM
jfrankjr's Avatar
jfrankjr
I finally figured out where the exhaust leak is coming from. It's where all 4 exhaust pipes come together. Right in the middle. The exhaust guy says I have to replace the manifold, but I read on another forum that it can be MIG welded. How would that be possible? Anyone do this?
Old Sep 29, 2017 | 04:50 AM
Capt_bj's Avatar
Capt_bj
the metal can be welded
getting in there to do the weld is the problem ..... access!
Old Sep 29, 2017 | 09:32 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
hit and run threads
You started three threads on your exhaust problem.
Old Sep 29, 2017 | 09:35 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
He is trying to exhaust all avenues of inquiry!
Old Sep 29, 2017 | 11:51 AM
nkfry's Avatar
nkfry
It is involved. I did it on my old MINI, you have to cut the header at the end of the collector just before the flexpipe, then weld from the inside. It'll look like a crosshair once you cut the header and I welded the whole cross as well as the center, where the weld is blown out on yours currently. Depending on who you have do it you could be into it for $250-300, which would be a few hundred short of just buying a used manifold off of car-part.com
We have a manifold that is prewelded ready to go, but shipping cost won't be cheap.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Sep 29, 2017 | 01:39 PM
jfrankjr's Avatar
jfrankjr
The problem with buying used is Car-part is only showing 3 of them available that fit my car :/
Old Sep 29, 2017 | 04:51 PM
Eric_Rowland's Avatar
Eric_Rowland
That's two more than you need, no?
Old Sep 29, 2017 | 08:04 PM
jfrankjr's Avatar
jfrankjr
Unfortunately they are not close. Closest one is 300 miles away. It's odd, I have an 08 S convertible and it's only showing manifolds from 07 and 08. I thought it should be the same as the R53s but it looks like they changed something on the 07 and 08 models.
Old Sep 29, 2017 | 10:11 PM
RB-MINI's Avatar
RB-MINI
Do you have a manual or an auto? The autos have a different manifold, probably due to the engine being shifted towards the passenger side. I think it's about a 1/2 to 3/4 of an inch.
Old Sep 30, 2017 | 06:45 AM
jfrankjr's Avatar
jfrankjr
It's an auto but it's only showing manifolds from 07 and 08 so I'm thinking something else must be different too, or their search engine is screwed up.
Old Oct 2, 2017 | 11:17 AM
nkfry's Avatar
nkfry
Change the search year to anywhere between 2003-06, their search engine is probably bringing up second gen cars due to the year break.
Phone:586-792-6464
pnwR53S
31
Oct 16, 2017 12:03 PM
