Harmonic Balancer / Belt Tensioner damaged MCS '04
Old Sep 7, 2008 | 03:41 PM
  #26
jlloyd's Avatar
jlloyd
Alright, I made it through Gustav relatively unscathed. Still no electricity BUT no damage to my house, save for a few shingles. I was also able to move my car to a safe location and it made it through without a scratch (thanks Dad!!!!). I haven't ordered or even been able to check if my dealer has the belt tensioner assembly in stock. Question; OEM or Aftermarket? IS there an aftermarket ASSEMBLY available. I'm going to go ahead and install the Detroit Tuned safety strap/bracket keeper thingy but, the only aftermarket piece slightly pertaining is the Idler Pulley by BBR. The Idler is NOT the Tensioner, I know. ideas? Anyone...anyone?
Old Sep 12, 2008 | 09:43 AM
  #27
ddawson's Avatar
ddawson
I bought a used 2003 MCS and we found it was making a clicking noise in the belt area. From some reason we didn't hear it on the test drive.
It seems to happen as soon as you give it some gas from a stop. It's not really there at idle. I brought the car to a Mini repair place that builds Mini race cars. I had them replace the SC pulley and he replaced the tensioner which reduces the noise by 75%. He said the crank pulley was starting to fall apart so he ordered a replacement. He thinks that will fix the rest of the noise.
Old Sep 15, 2008 | 08:04 AM
  #28
ih8cornnuts's Avatar
ih8cornnuts
Curious if replacing the harmonic balancer with a newer style (05+ I believe) would be beneficial for older cars as those weight drastically less as opposed to an underdrive pulley.
Old Sep 15, 2008 | 11:11 AM
  #29
pepegrande008's Avatar
pepegrande008
just buy a one piece!!! its so much better
Old Sep 15, 2008 | 11:49 AM
  #30
pepegrande008
im pretty sure they are the same anyways???
http://new.minimania.com/web/item/NME7647/InvDetail.cfm
Old Sep 15, 2008 | 12:24 PM
  #31
volki
Well, I dont know about performance addition, power output, etc, but price wise, they are definitely not the same compared to the OEM. I had the Crank Pulley replaced on my 03 MCS with the newly designed one about 6 months ago. I purchased the part from a dealer (with wholesale discount) for about $280. The one at MINImania is for $460
Old Sep 15, 2008 | 12:26 PM
  #32
volki
Yes it will take care of the clicking noise that shows up when over 3K rpm and driving next to a wall, divider, etc with the passenger side window down. Many of us reported that the clatter goes away with the updated harmonic balancer (crank pulley).
Old Sep 15, 2008 | 04:09 PM
  #33
damins212's Avatar
damins212
well i have 19% pulley reduction and idk if my pulleys are either unaligned or i dont know whats wrong with it if someone could please help that would be nice because my car is breaking the belts really quickly
Old Sep 15, 2008 | 04:25 PM
  #34
damins212's Avatar
damins212
Originally Posted by Helix13mini
We just got a Customer's car back from Watkins Glen that did the same thing. This was his umpteenth track day this year, and his belt gave up--probably due to the faulty dampener (the little black shock absorber on the tensioner bracket).
I am seeing more and more of the dampener failures, and one of my MINI dealer tech buddies says that he's replacing alot of tensioners under warranty. You can tell if your dampener is really bad by running the motor at idle and looking at your tensioner pulley. That's the one that is just below the supercharger pulley, attached to the metal bracket with the spring on it. if it is dancing back and fourth under the spring tension, your dampener is faulty. This can heat up your belt and cause it to fail. Another common failure is the tensioner or idler pulley bearings which can also cause your belt to fail. If you need help identifying these, you can call me and I'll describe it.
These belt failure causes are happening on stock cars, and are not the fault of the smaller pulley. If you dealer refuses service, ask to see the broken parts and check for bad bearings in the pulleys, as well as that dampener. Again, I'd be happy to describe to you what to look for.
When the tensioner bracket breaks, the tensioner spring forces the broken piece of aluminum bracket into the crank pulley (harmonic balancer). both parts do a pretty good job of machining each other. So I think that your dealership is correct about needing a new crank pulley.
In my opinion, it is likely that your belt failure was the effect of one of three things: bad tensioner pulley, dampener, or idler pulley. Of course they will try to avoid the warranty work, but if you go armed with some information and a bad attitude, you have a good shot at prevailing.
Hey Helix listen i have an 03 MCS and its giving me problems with my 19% pulley reduction. Its breaking the belts really quickly. I live in New York I know you guys are in Philadelphia but my dad doesnt let me take the car over there do u think you could help me out on telling me some possibilities of why its happening and some things i could do to fix it?
Spank
11
Apr 9, 2020 02:23 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
