04 MCS: Key won't open drivers side manually
Old Aug 17, 2017 | 08:17 PM
777madmax's Avatar
777madmax
Hi all,
Has anyone experienced this issue before? I just got home from work and now the key goes in the lock, but it won't budge. Tried locking and unlocking from the inside and it works fine, but the key won't do anything from the outside. Im forced to leave my car unlocked so I don't get locked out completely, so I obviously need to get this done ASAP so my car doesn't get ripped off. Any advice? Thanks
-Max
Old Aug 17, 2017 | 08:59 PM
808R53's Avatar
808R53
Wd40
Old Aug 18, 2017 | 11:30 AM
Jimmyjamesphan's Avatar
Jimmyjamesphan
Maybe they changed the door and didn't swap over the key hole
Old Aug 18, 2017 | 12:10 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Gone to move you to the Stock Problems/Issues area.
This is both doors and if you a have a spare it does not work either. If only one key, then could be the key is worn and will not push the pins correctly. If both keys don't work then the pins inside the lock are bad.
Old Aug 18, 2017 | 04:35 PM
valvashon's Avatar
valvashon
Sounds like you are using a "general, non-remote" key correct? Or is it a remote key that doesn't work?
Either way, try some graphite lock lubricant as that is very good for lock cylinders- it won't gum up or attract dirt like WD-40 will. If the lock cylinder still won't budge it's probably bad- they are not meant to be used everyday. The replacement ones are of better quality but the OEM ones were really meant for occasional use only.
Replacement ones are sold through the dealer individually and ready to go for your key- they are made to order via your VIN and set up for your key. You do not need to buy a whole new set of keys and ignition and door locks- the door cylinder is available individually.
Also, the door lock is more forgiving, so if anything is going to react negatively to a worn key it's the ignition cylinder.
Val
