2006 rear wiper R 50
Old Feb 22, 2017 | 12:54 PM
coopermike29's Avatar
coopermike29
I have searched for a replacement rear wiper blade only and I only found one at the dealer.
Does anyone know of any other place might have these ?
Our local O'reilley, pep boys , autozone do not.....
Appreciate all your responses
Old Feb 22, 2017 | 01:04 PM
Thinker2112's Avatar
Thinker2112
The full wiper arm or just the blade insert?
Old Feb 22, 2017 | 01:12 PM
coopermike29
blade insert
Old Feb 22, 2017 | 01:15 PM
gumbedamit's Avatar
gumbedamit
Originally Posted by coopermike29
blade insert
https://smile.amazon.com/Genuine-MIN...50+wiper+blade
Old Feb 22, 2017 | 08:15 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We have them
https://www.waymotorworks.com/rear-w...e-r50-r53.html
Old Feb 22, 2017 | 08:24 PM
X757XVeritas's Avatar
X757XVeritas
Pfffff all the cool kids are deleting the rear wiper anyhow....
I just popped the motor and arm off, got a plastic pipe plug and siliconed it into the hole.
The spring was shot in my wiper arm and it rattled like crazy against the window. The plug was less than a dollar and I had the silicone. Might get a new arm and reinstall one day. It sure gets dirty back there. My washer fluid wouldn't spray either so I'm not sure whats up with that.
Old Feb 23, 2017 | 08:46 AM
Thinker2112
The local dealership told me that they are not doing the inserts for the rear anymore on 2005 or later and that they have discontinued the metal bands for the front inserts so you have to save the old ones. I told them to pound sand.
Old Feb 23, 2017 | 09:47 AM
coopermike29
Thanks for all the replies. ..the Amazon one will NOT line up.
I checked. ...my rear wiper has a more severe slant....about ONE inch..vs. Amazon 1/2 inch
I read somewhere that mini changed styles sometime in 2005 -2006
might just go to pepboys and try to match..
Old Feb 23, 2017 | 10:37 AM
Thinker2112
They did. The 2004 and 2005 rear blades are different. I actually broke mine this winter from snow and ice. I had a 2005 arm because it broke and it wouldn't match up to the 2004 and had to get a 2004 arm. Pull out the metal strips in the old blade insert and use a new front blade insert and cut to length - just like they used to sell at the dealership for $3 each.
Old Feb 23, 2017 | 11:58 AM
WayMotorWorks
Vendor
Yes they have two different shapes, that is why we have a picture to show both styles and allow you to order the correct one.
Old Feb 23, 2017 | 12:07 PM
JimR56JCW's Avatar
JimR56JCW
I just bought a generic blade from local parts store. Removed the insert and put it in the MINI blade. 11 inch
Attached Thumbnails 2006 rear wiper R 50-img_9575.jpg   2006 rear wiper R 50-img_3419.jpg
Old Feb 23, 2017 | 05:25 PM
coopermike29
I was thinking of just getting a generic blade to replace....... just the blade.
I have style A according to WMW. Which has 4 areas to " clip in" the blade.
Style B has 3...which is much easier to replace.
I'll let you know how it goes ...though not a high priority
Thank you again for all the great advice/ ideas !!!
Old Feb 23, 2017 | 06:19 PM
Whine not Walnuts's Avatar
Whine not Walnuts
On my r53 I bought a blade and cut it down to fit.
Old Feb 24, 2017 | 02:27 PM
Capt_bj's Avatar
Capt_bj
YEP
If you look at the wiper .... it is EASY to slide out the rubber blade portion
just carry the old blade - just the rubber part - into the auto part store and find an insert that looks the same - no matter the length.
Then cut it down and slide it in. I replaced mine often .... I could replace this way 5 times for the price of one factory fix!
Old Feb 24, 2017 | 04:04 PM
JimR56JCW's Avatar
JimR56JCW
If you get an 11 inch one, there is no cutting. There are 2 steel bands on the rubber part.
Old Feb 25, 2017 | 12:05 PM
coopermike29
problem SOLVED !!!
Pepboys .....nothing
Advanced Auto Parts....nothing
BUT....Oreilliys DOES HAVE INSERTS !!!!
Its Trico 44-170. They come as a 2 blade set for $7.99
Slid into the 3 wiper blade holder sleeves...cut to length.....then put the blade into the 4th sleeve.
I did this with the wiper OFF the car. Just snaps on and off !!
Thanks for ALL the help !!!!!
Old Feb 25, 2017 | 01:52 PM
DJLMINI's Avatar
DJLMINI
The line before the nozzle tends to get clogged. Can be cleaned out by running the washer motor and running some wire down it, with the nozzle out of the way.
Old Feb 26, 2017 | 07:47 AM
Bernard Barbour's Avatar
Bernard Barbour
I just did this job a few days ago. It was easy and I ordered a new blade from ebay. All good now.
Old Feb 26, 2017 | 09:12 AM
coopermike29
nice pics !!!
