squeaky noise from engine
Old Jan 21, 2017 | 02:40 PM
  #26
froggy_07's Avatar
froggy_07
i ll search for some vids, i watched the one that was posted here.
Old Jan 21, 2017 | 02:51 PM
  #27
froggy_07's Avatar
froggy_07
thank you very much
Old Jan 21, 2017 | 03:15 PM
  #28
froggy_07's Avatar
froggy_07
i have one last question if its ok
Old Jan 21, 2017 | 03:34 PM
  #29
froggy_07's Avatar
froggy_07
Old Jan 21, 2017 | 03:36 PM
  #30
froggy_07's Avatar
froggy_07
as I was looking around i found this. Is that an oil line that goes to something? looks as if its been leaking.
Old Jan 21, 2017 | 04:11 PM
  #31
RB-MINI's Avatar
RB-MINI
Originally Posted by froggy_07
no it wasn't, but they advertised European makes (BMW, Mercedes, VW) I wish I knew more about these cars and how they worked. Id do the work myself. So from the picture the belt tensioner was already replaced before?
It probably has been replaced since it has Litens branding on it. It's not unusual for the tensioners to go bad, almost always due to the strut going bad. So far no one has found a compatible replacement strut so the whole tensioner gets replaced.
Another tensioner option is the AC Delco tensioner which is also supposed to be made by Litens. Currently, the AC Delco is on Amazon for less than $100.
Could this be the problem?
https://youtu.be/SfzOtsW6Nfo
Old Jan 21, 2017 | 04:26 PM
  #32
froggy_07's Avatar
froggy_07
finally found a way to have a video of it. Ok here's the link,
https://youtu.be/6Sgz0xs2AUA
Old Jan 21, 2017 | 04:45 PM
  #33
Whine not Walnuts's Avatar
Whine not Walnuts
I suggest you repost this on both the R53 thread and the General Mini threads as I think you will get better coverage and some of the vendors will also chime in. I am thinking its the crank harmonic pulley. There are some guys here that will know for sure from the vid. I would not drive the car until these other guys chime in,
Need to get ECS, Way Motors and Madness Mini to see this.
As far as the oil line, where is that area on the motor.
If you can turn a wrench you can work on your Mini. The tensioner and crank pulley area are not that bad and Mod Mini has vids on everything that the belt runs over.
Old Jan 21, 2017 | 04:55 PM
  #34
froggy_07's Avatar
froggy_07
that little hose is on the back side
Old Jan 21, 2017 | 04:58 PM
  #35
froggy_07's Avatar
froggy_07
ill check out those videos and hopefully will have it back and running correctly. what should I label this video in those other forums?
Old Jan 21, 2017 | 05:11 PM
  #36
froggy_07's Avatar
froggy_07
i labeled it the same as it is here. and posted the the youtube video. I will not drive it until its fixed.
