no boost reading...
Old Feb 17, 2017 | 04:30 PM
  #26
BruceJ's Avatar
BruceJ
Alternator voltage
There is nothing wrong with the voltage level you are seeing. That is normal alternator operation. Voltage output depends on charge of the battery, rpm and accessory current draw.
Old Feb 17, 2017 | 09:14 PM
  #27
Mini_Chan's Avatar
Mini_Chan
Oh ok I thought it was higher. Thanks for clarifying for me.
Old Mar 9, 2017 | 07:13 PM
  #28
Mini_Chan's Avatar
Mini_Chan
Will a slipping clutch cause a low to no boost reading? My recent venture to the dealership has told me my clutch is starting to slip and my crank pulley is loose.
Old Mar 9, 2017 | 08:09 PM
  #29
lemarzmini's Avatar
lemarzmini
No, slipping clutch will not affect your boost reading.
slipping clutch basically means your engine is not transferring the power to the transmission.
Old Mar 10, 2017 | 05:18 AM
  #30
Mini_Chan's Avatar
Mini_Chan
oh ok the dealership didn't diagnose my problem then :(
Old Mar 11, 2017 | 08:40 AM
  #31
ItsmeWayne's Avatar
ItsmeWayne
I totally agree !
The slipping/bad vibration dampener is you problem! These go out often! And they will kill your boost and also stop your AC from working, as the compressor will stop the belt too.
Old Mar 11, 2017 | 03:52 PM
  #32
Mini_Chan's Avatar
Mini_Chan
My AC still works, but I guess its just beginning to fail. It's a good thing I have an ATI dampener waiting to be put on once its warmer.
