Interesting find - hissing noise diagnosed
Old Jan 9, 2017 | 07:11 PM
Grip Grip's Avatar
Grip Grip
I bought an 06 MCS last month and was hearing hissing from the passenger side of the engine near the fuel tank vent solenoid. After spraying a bottle of soapy water on all the lines, removing/reinstalling the intercooler 4 times, and replacing 2 vacuum lines, I finally located the hissing. The hissing turned out the be the far injector on the passenger side (cyl 1?).
While spraying the vacuum lines I went ahead and sprayed the injectors, since my makeshift stethoscope was indicating on that area. As soon as the soapy water hit the injector the RPM's fluctuated like crazy. The hissing in this case was air being pulled into the cylinder, since there was no bubbling from the soap.
I pulled the fuel rail and found the injector seals were dirty, and the o-ring on the particular injector was cut on the cylinder side.
I cleaned all o-rings and reversed the damaged o-ring and now all is well.
Just figured I'd post it.
Old Jan 9, 2017 | 09:12 PM
Scooter24's Avatar
Scooter24
Awsome find!
Old Jan 11, 2017 | 05:04 AM
traildog's Avatar
traildog
Thanks for taking the time to share that.
Old Jan 11, 2017 | 09:22 AM
Grip Grip's Avatar
Grip Grip
Originally Posted by Scooter24
Awsome find!
Thanks and you're both welcome. Hopefully this will save the next guy a little time in pinpointing the issue.
Old Jan 11, 2017 | 03:02 PM
Mini Mania's Avatar
Injector
Great info, thanks for sharing.
Old Jan 11, 2017 | 03:43 PM
*CharlieHustle's Avatar
*CharlieHustle
I had a hissing from around the same area on my 05 r53. Turned out to be a rubber vacuum connection that had broken down and developed a hole.
