Engine temp indicator came on.
Old Oct 12, 2016 | 01:33 PM
  #26
sirr6's Avatar
sirr6
Originally Posted by MiniToBe
there is no need for special tools. the only special tool you need is your hands it is a fairly medium to easy job. the tool they are mentioning is something like a handle that helps releasing the tension off the serpentine belt. then there is pin on the assembly that holds the armature in place.
Thanks minitobe, I called mini yesterday and the advisor said the same thing. The tool only helps with the belt, I would do it myself but the instructions from pelican parts saids the car should be on a lift and I don't have access to one.
Old Oct 12, 2016 | 02:17 PM
  #27
MiniToBe's Avatar
MiniToBe
I dont think you need a lift. If i remember correctly, there is enough space to squeeze your hands in there. You will need to take the motor mount bracket off so you can lower the engine down. I also suggest getting the exhaust off of the rubber holders so it can move freely, somewhat. You will also need to take the mud guard off. Take a look and assess the space and location.
Old Oct 13, 2016 | 08:12 AM
  #28
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I don't believe our tech article states your MINI should be on a lift.
http://www.pelicanparts.com/techarti...eplacement.htm
The only note about lifting anything is in figure 3 about supporting the engine with a jack. We also show the whole process without any special tools. We do also recommend that when you're in there to replace the water pump that it wouldn't be a bad idea to replace the water pump pulley for added insurance as over time the rubber can become detached from the pulley or crack and wear out. We have them HERE if needed. Let me know if you have any questions after reviewing the article.
888.280.7799 | 6am - 5pm PST
Old Oct 13, 2016 | 03:35 PM
  #29
sirr6's Avatar
sirr6
Misread pelican parts. I will be ordering my parts this week.
TJANK
Jul 31, 2019 06:23 AM
Kristopher Sullivan
Tires, Wheels, & Brakes
12
Jan 10, 2017 07:33 PM
TJANK
Aug 18, 2016 02:55 AM
TJANK
Aug 15, 2016 11:28 AM
TJANK
Aug 10, 2016 11:46 AM
