I need help!!
According to your wording: The turbo is failing causing the warning light to come on rather than the light coming on making the turbo quit. Get it into a shop to find out why the turbo is failing and get it fixed. There are several things that can be causing the problem.
I would read the codes with a good scanner, see what the problem is and then fix it. You dont want to have a major issue with the engine then clear the light.
https://www.northamericanmotoring.co...d-q-and-a.html
Any number of things can cause limp mode, you need to have it properly diagnosed.
Russter500
Aug 17, 2016 06:51 AM
