PCV to supercharger line
Old Mar 6, 2016 | 08:45 PM
Ministrater's Avatar
Ministrater
So this line from the valve cover does not want to go flush with the rib. The red fitting is not broken. I am afraid to force it down in there. Does anyone have any tips to getting this to fit flush?
Old Mar 6, 2016 | 09:39 PM
tonester's Avatar
tonester
I just had to remove this vacuum line today. Have you tried to push down on the red fitting while pushing the line back in?
Old Mar 7, 2016 | 05:46 AM
Ministrater
Yes, I tried pushing on it and no dice. It may have been my fumbly fingers so I will try again. It looks like there is a green gasket/seal down in there that it is hitting the top edges rather than inserting into.
Old Mar 7, 2016 | 09:39 AM
David.R53's Avatar
David.R53
Make sure the end of the hose isn't damaged or have a butt that is catching the seal. Wipe the tip with a little motor oil will also help.
Old Mar 7, 2016 | 10:58 AM
Ministrater
The tip of the line looks intact but I will inspect closer for burrs and butts.
Thanks Dave & Tonester, for the replies.
Old Mar 7, 2016 | 11:15 AM
David.R53's Avatar
David.R53
Stoopid spell checker! Guess you figured out I meant burr.
Old Mar 7, 2016 | 11:42 AM
Ministrater
Haha, yeah, no worries.
Old Mar 7, 2016 | 11:56 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I've had those speed fittings fail in non automotive applications, plumbing or beer brewing without all the heat of an engine. A bit of grit can get in and foul it. I would try some Wd40 on it if it doesn't slide easily or get a replacement. GL
Old Mar 7, 2016 | 12:33 PM
Ministrater
Thanks Moocher.
My primary concern is that internal seal and being careful is the name of the game for sure.
Old Mar 7, 2016 | 07:29 PM
Ministrater
Success! There was a tiny lip on the end of the tube that I sanded off ever so gently. Upon closer inspection there is a green o-ring in the hole which is a tight fit. I lubed up the tube and used some firm persuasion to sink it in flush. Now it's seated perfectly.
Old Mar 8, 2016 | 06:37 AM
Great, its a tight fit and must have been a little piece of plastic from the molding that needed sanded off
Old Apr 19, 2016 | 09:23 PM
bresparta's Avatar
bresparta
What would you call the red gasket/rubber piece that holds that line in to the supercharger? Mine is missing it.
Old Apr 19, 2016 | 11:12 PM
Minnie.the.Moocher
Collet?
Old Apr 20, 2016 | 03:38 PM
Shawnnn's Avatar
Shawnnn
http://www.waymotorworks.com/superch...p-r52-r53.html
MrSurly
Aug 28, 2020 12:43 PM
GPToyz
May 26, 2016 02:31 PM
donniedarko
Mar 2, 2016 08:11 AM
Mar 1, 2016 04:44 PM
Mar 1, 2016 11:55 AM
