Radiator Question
Old Mar 4, 2016 | 09:45 AM
05r53ChiliRedMini's Avatar
05r53ChiliRedMini
Radiator Question
Hi, I just replaced my radiator on my 2005 MCS. I Have yet to fill it with fluid. I was wondering if I can just pour it straight in and start the car or if i need to do anything special. Any help will be great
Old Mar 4, 2016 | 09:50 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Check out our coolant change article on our site under MINI > Tech Info (tab at top), water cooling, Coolant Change. Since you removed coolant from the system you'll want to bleed the system. At this time, it may be a good idea to do a coolant change if you haven't done one in a while. Make sure you're using MINI blue coolant 50/50 mixture with distilled water. Let me know if you have any questions
http://www.pelicanparts.com/catalog/..._pg1.htm#item0
888.280.7799 | 6am - 5pm PST
Old Mar 4, 2016 | 10:29 AM
you will need to mix it 50/50 with distilled water. You will also need the specific fluid , recommend the MINI blue coolant as that's whats most likely in there before.
https://www.northamericanmotoring.co...nt-system.html
CLMINIR53
Mar 14, 2016 07:45 AM
Saovalle
Tires, Wheels, & Brakes
20
Mar 9, 2016 04:18 PM
btwice
11
Mar 9, 2016 11:38 AM
TxMINIMama
Mar 7, 2016 09:15 AM
sannweinstein
Mar 7, 2016 07:33 AM
