Can someone identify this piece and where it belongs?
Old Jan 14, 2016 | 09:43 PM
L3Mix's Avatar
L3Mix
So i discovered this piece uncovered with with a bit of copper wiring exposed. Exactly where is it connected and what does it do?
Old Jan 15, 2016 | 01:34 AM
L3Mix's Avatar
L3Mix
Nevermind. Figured out it was a grounding cable which somehow disconnected. Next question, what's the black hollow tubing that is also connected to the fuel filler line? Could it trip a p0455 code if it is torn or ripped?
Old Jan 15, 2016 | 08:56 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Yep, ground wire. Definitely make sure that is installed back in nice and snug. That black tube is I believe the fuel tank filler pipe assembly HERE, #10 below. The attached hosing below it is the fuel hose HERE, #11 below. I can see this tripping an evap code if torn.
888.280.7799 | 6am - 5pm PST
Old Jan 15, 2016 | 11:45 AM
Unbreakable Lump's Avatar
Unbreakable Lump
The black plastic conduit is covering the vapor return hose/line to the fuel tank. A cut of the conduit isn't a problem, (it's only there to protect the line), but a leak or cut in that return line will throw a CEL (same one as for loose gas cap). Sorry, I don't know the codes.
Old Jan 18, 2016 | 07:02 AM
nkfry's Avatar
nkfry
P0455 is for a large evap leak detection, which if there was an ungrounded circuit could be reason for that code. The system will never be able to pull vacuum as it is an open electrical circuit without ground, fix the exposed wire, affix the ground, clear the codes and see what returns. If you do in fact have a large evap leak you will need to further diagnose the problem.
Usual suspects are gas caps, cracked charcoal canisters (road debris), dirt packed in vacuum line connections at the DMTL/ charcoal canister.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 18, 2016 | 10:23 AM
How did it come loose ?
Steffen.Johnson
Jul 14, 2016 02:03 PM
MrHorsepower01
Jan 29, 2016 01:24 PM
vulkandino
Jan 17, 2016 09:07 PM
jsb
Jan 15, 2016 05:34 PM
minigen
Dec 29, 2015 05:37 AM
