any tips to remove the throwbearing shaft?
Old Nov 28, 2015 | 01:20 PM
buggyeye401's Avatar
buggyeye401
whats up all!
in the middle of replacing my clutch. figure i replace the seals and bushing on the transmission. im stuck on the throwbearing shaft. Been trying to pull/hammer the shaft out but the throw bearing fork is stuck on the shaft tight. pelicanparts diy said to use adjustable wrench but ive tried and no luck. anyone have another tip for me to try?
Old Dec 1, 2015 | 06:55 AM
nkfry's Avatar
nkfry
Remove the bolts holding it on, and a slight tap with a hammer should break it free of the trans, shouldn't need anything to grip and rip with.
You aren't speaking of the input shaft are you? That won't come out unless the trans case is opened.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 1, 2015 | 07:00 AM
Helix13mini's Avatar
Helix13mini
Yep, I don't think he's talking about the guide tube. OP, can you post a pic of what you're talking about?
Old Dec 1, 2015 | 11:39 AM
buggyeye401
its the throwbearing rid with the fork that pushes the throwbearing up and down. stupid thing wont budge. i tapped it pretty hard and nothibg.
Old Dec 4, 2015 | 07:10 PM
valvashon's Avatar
valvashon
Perhaps the Getrag cases are different, but on the Midlands cases it is very easy to crack the case while trying to hammer this fork (with a slightly different design) out. Brute force is probably not the answer here.
Lex2008
Aug 9, 2024 12:54 PM
Andrew Riley
Jan 19, 2016 08:58 PM
Deezums
Nov 26, 2015 06:27 PM
BLMW
Nov 26, 2015 09:28 AM
USA-RET
Nov 26, 2015 07:48 AM
