Chrono Pkg Help
Old Dec 29, 2014 | 08:24 AM
KrisMiss's Avatar
KrisMiss
Chrono Pkg Help
So I need some help with figuring out what happened to one of the gauges. I got a botched oil change (shame on me for not doing it myself) and ever since only 1 of the gauges doesnt show a reading. Its the oil on the lower set below the radio/behind the lighter. It doesn't move at all.
I'm on phone so I can't look up much but what I'm wondering is... Is there any way 1 cable was disconnected or damaged to cause this?
Old Dec 29, 2014 | 08:47 AM
For the Aux Gauges set:
82940415253
The oil temp sensor is the different oil drain plug / sensor combo. If they botched the drain plug on that and replaced it with a normal plug, you will have no reading.
Normal plug: 11137513050
http://www.ecstuning.com/Search/SiteSearch/11137513050/
Aux kit plug: 82940004581
https://www.northamericanmotoring.co...ic-inside.html
You will just need a new sensor plug 82940004581 and then plug in that single wire that should be hanging somewhere.
Old Dec 29, 2014 | 09:00 AM
KrisMiss's Avatar
KrisMiss
You're awesome. Thanks so much.
Old Dec 29, 2014 | 09:48 AM
You are welcome.
boholio
Nov 9, 2015 03:50 PM
tEckniks
Sep 29, 2015 11:20 AM
bahman
Sep 26, 2015 07:38 PM
stellaherself
Sep 16, 2015 06:56 AM
