Where's the most likely place i'm leaking coolant?
Old Mar 27, 2014 | 03:56 PM
donjulio's Avatar
donjulio
base on this photo :
Old Mar 27, 2014 | 07:38 PM
wailone's Avatar
wailone
check the thermostat
check the thermostat - I had a similar location (back behind firewall) and was told there were some o-rings on the thermostat. Opted to replace all together. I had some bigger issues after, but this was source of coolant leak..... check thermostat housing leaks on here. I'll see if I can locate the one I read.... Good luck
Old Mar 27, 2014 | 09:33 PM
ashchuckton's Avatar
ashchuckton
Thermostat housing, or weep hole from the water pump. Possibly both.
Old Mar 27, 2014 | 09:57 PM
ZippyNH's Avatar
ZippyNH
did you pop open the hood and look? Maybe you can spot where the drips are coming from....
Not trying to be a smart azz...but nothing beats a close look to save one from going on a snipe hunt....
Old Aug 22, 2014 | 06:58 AM
HyTech's Avatar
HyTech
From: Part year in Portland OR, part year Kalamazoo MI
One thing I've used to find those elusive damn leaks is to buy some ultraviolet coolant dye and put it into the coolant, then on a dark night and with an ultraviolet flashlight the leak is easy to find. (Of course, it was kin the most inaccessible spot possible.) Many coolants already have the dye in it, so the UV flashlight may work anyway.
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 3, 2015 01:45 PM
Suspension Products
Sep 3, 2015 09:41 AM
Sep 2, 2015 09:05 AM
